Auto logoff PC in given time
karthie
@karthie-UlD8ye • Oct 25, 2024
Hi friends,
Is there any code to auto logoff the PC in given time? I have seen some software to logoff, shutdown, restart the PC automatically. But I need some coding in any language to do so, by showing the alert msg that the system is going to logoff in some seconds.. like that..
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD • Mar 5, 2010
    Are you looking for the MS DOS command?
    "shutdown -s -t 10" - To shutdown the computer after 10 seconds.
  • karthie
    karthie OP
    @karthie-UlD8ye • Mar 5, 2010
    No, we can use the batch file "shutdown -s -t 10" to logoff the PC by clicking it. But I need a program which runs automatically once we login the system by setting the logoff time. For eg: you can see this in Sify Iway.
  • gaurav.bhorkar
    Well I don't have any idea about SifyIway.
    You can use this "shutdown" command in a C program also with the help of "system()" function.
    Let me give an example program:
    #include <stdio.h>
    #include <stdlib.h>
    void main ()
        system ("shutdown -s -t 60");
    Copy the exe file of this program into the StartUp folder in Start Menu.
    The computer will shutdown after 60 seconds each time it starts.
  • durga ch
    @durga-TpX3gO • Mar 5, 2010
    unix has corn jobs which can be set up. Not sure of windows though
  • MaRo
    @maro-Ce3knx • Mar 6, 2010
    gaurav.bhorkarWell I don't have any idea about SifyIway.
    #include <stdio.h>
    #include <stdlib.h>
    void main ()
    That's right, more for letting user enters a specific time hh:mm:ss, just get the current time & subtract from the given time convert to seconds & pass it to system().
  • saurabh2486
    @saurabh2486-Tr6NOC • Mar 11, 2010
    yes there is a command check this out this might help
    Microsoft DOS shutdown command
    Quick links
    #-Link-Snipped-##-Link-Snipped-#
    About shutdown
    Enables a user to shutdown a Windows XP computer from the command line as well as perform additional features that are not available through Windows.
    [​IMG]Availability
    The shutdown.exe command is an #-Link-Snipped-# available in the below Microsoft Windows operating systems.
    Index
    Category:
    Companies:
    Related Pages:
    Resolved
    Were you able to locate the answer to your questions?
    • <a href="https://www.computerhope.com/cgi-bin/feedback.cgi?yes" target="_blank" rel="nofollow noopener noreferrer">Computer Hope Feedback</a>
    • <a href="https://www.computerhope.com/cgi-bin/feedback.cgi?no" target="_blank" rel="nofollow noopener noreferrer">Computer Hope feedback and recommendations</a>
    Syntax
    Usage: shutdown [-i | -l | -s | -r | -a] [-f] [-m \\computername] [-t xx] [-c "comment"] [-d up:xx:yy]
    No args Display this message (same as -?)-iDisplay GUI interface, must be the first option-lLog off (cannot be used with -m option)-sShutdown the computer-rShutdown and restart the computer-aAbort a system shutdown-m \\computernameRemote computer to shutdown/restart/abort-t xxSet timeout for shutdown to xx seconds-c "comment"Shutdown comment (maximum of 127 characters)-fForces running applications to close without warning-d [p]:xx:yyThe reason code for the shutdown
    u is the user code
    p is a planned shutdown code
    xx is the major reason code (positive integer less than 256)
    yy is the minor reason code (positive integer less than 65536)Examples
    shutdown -r -c "Rebooting for latest updates."
    This would display a Windows System Shutdown window for 30 seconds, warning the user that the computer is going to shutdown and then restart the computer.
    shutdown -i
    Ran from either the command line or from the Windows run line this option would open the remote shutdown dialog Window. See #-Link-Snipped-# for additional information and an example of this window.
    Additional information
    • If you are running Microsoft Windows 95, 98, NT, or 2000 and/or you wish to find out other methods of restarting or shutting down your computer from the command prompt, please see #-Link-Snipped-#.
    • See #-Link-Snipped-# for additional information about remotely shutting down a computer in Windows.
    Quick links
    About shutdown
    [​IMG]Availability
    Index
    Category:
    Companies:
    Related Pages:
    Resolved
    Syntax
    u is the user code
    shutdown -i
    u is the user code
    yy is the minor reason code (positive integer less than 65536)here switch -l is used for logoff rest if u need to understand ask me
