Atypical InFlow (Turbo-Rotary) Thermodynamic Technology Submission - Gearturbine Proj
retrodynamic
@retrodynamic-WJCczm • Oct 23, 2024
*Atypical InFlow (Turbo-Rotary) Thermodynamic Technology - Gearturbine Project
😉GEARTURBINEPROJECT
Atypical InFlow Thermodynamic Technology Submission
Innovative (Turbo-ROTARY) Fueled Motor Engine Type
*The Gearturbine comes from the contemporary ecological essential global needs of a efficient power plant fueled motor engine.
-Power thrust by bar (tube); air, sea, land, power generation, work application.
-Have the same simple basic system of the "Aelopilie" Heron´s Steam Turbine device from Alexandria, (10-70 AD) one thousand nine hundred years ago. Because; the circular dynamic motion, with 2/Two Opposites power (polar position) lever, and is feeds from his axis center.
YouTube Video/10.30 min; Atypical New * GEARTURBINE / Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Thrust Way Type - Non Waste Looses
<a href="https://www.youtube.com/watch?v=0cPo9Lf44TE" target="_blank" rel="nofollow noopener noreferrer">Atypical New*GEARTURBINE/Retrodynamic=DextroRPM VS LevoInFlow+YingYang ThrustWay Type-NonWasteLooses - YouTube</a>
*8-X/Y Thermodynamic CYCLE - Way Steps:
1)1-Compression / bigger
2)2-Turbo 1 cold
3)2-Turbo 2 cold
4)2-Combustion - circular motion flames / opposites
5)2-Thrust - single turbo & planetary gears / ying yang
6)2-Turbo 2 hot
7)2-Turbo1 hot
8)1-Turbine / bigger
*State of the art. Innovative Turbo-Rotary technology Top system.
-With Retrodynamic dextrogiro vs levogiro phenomenon effect. / Rotor-RPM VS InFlow / front to front "Collision-interaction Type" - inflow vs blades surface/(gear). Technical unique dynamic motion mode.
-Form-function (flat) wide cilindrical shape / continue kinetic inertia, positive tendence dynamic mass motion. The rotary motor weight is going with the circular motion power thrust.
-Non-waste parasitic looses system for: cooling, lubrication & combustion.
-Combustion 2Two (Inside dynamic) continue circular flames (like 2two opposite rockets, (at the same axis)).
-2 Two (very) long captive compression inflow propulsion conduits. start were ends, in perfect shape balance.
-4 Turbos (rotary & translation motion) inside active.
-Mechanical direct 2two planetary gears thurst, inside in a bigger shell, total lever, polar position. (Big torque) (like the Ying Yang simbol concept).
-3 stages of inflow turbo compression before combustion; 1)1-Turbine, 2)2-Turbos 3)2-Turbos.
*The most innovative power plant motor engine project today. Higher efficient % percentage. Next trend wave toward global technological coming change.
Patent; Dic 1991 IMPI Mexico #197187 - Carlos Barrera. - Individual Designer - Inventor and project owner. / All Rights Reserved. - Monterrey, NL, Mexico. 😀
    @thebigk Jul 8, 2011
    Re: Atypical InFlow (Turbo-Rotary) Thermodynamic Technology Submission - Gearturbine
    Post approved.
  • ShrinkDWorld
    @shrinkdworld-WWdBBc Jul 11, 2011
    very hard to understand!!
  • retrodynamic
    @retrodynamic-WJCczm Jul 12, 2011
    Hey, gg_gaurav, thanks to see my post.
    But well what can I say about your coment, my project its a rotary device. To activate his systems, only needs to make a turn to work, that simple is.
    But yes I know what you talking about, and is because I try to explain and show the technical qualities of the diferent system, in diferent lines, thats why.
    I sugest to see all systems in just a big one concept.
    And what can I say, for me looks very simple, any way.
