arrangement problem
Banashree Patra
Banashree Patra
@banashree-patra-m0OJwR Oct 25, 2024
The integers 1, 2,........., 10 are circularly arranged in an arbitrary order. Show that there are always three successive integers in this arrangement, whose sum is at least 17.
  • Prashanth_p@cchi
    Prashanth_p@cchi
    @prashanth-p-at-cchi-rg0z63 May 23, 2012
    Question may be confusing for many! It seems that no one is interested to make an attempt.
    Could you please provide us the answer?
  • Sagar07
    Sagar07
    @sagar07-LecI1i Jun 12, 2012
    Well, it is obvious.... But, i wonder, how can one prove it????????
    @abrakadabra Jun 12, 2012
    That is actually a bit difficult to prove.
    This a good sequence ->
    1, 10, 6, 2, 8, 7, 3, 5, 9, 4.
    None of the 3 consecutive numbers have a summation of less than 17 and it is at most 18.
  • Prashanth_p@cchi
    Prashanth_p@cchi
    @prashanth-p-at-cchi-rg0z63 Jun 12, 2012
    AbraKaDabra
    how about the one's marked above?
    Prashanth_p@cchi
    Oh yes. In a hurry I only checked these
    1,10,6
    10,6,2
    2,8,7
    8,7,3
    9,5,3
    5,9,4
    Now, that I think about it, since it is a circular arrangement 9,4,1 is also not proper.
  • Prashanth_p@cchi
    Prashanth_p@cchi
    I think its impossible! but I might be wrong.
    Below is the least in terms of the entire sum, that can be used to satisfy the above criteria.
    6,6,5,6,6,5,6,6,5,6 which adds up to - 57
    But 1-10 adds up to 55.😔
  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M Jun 12, 2012
    Consider the numbers 1 to 10 are marked as 1 , x1, x2, ... , x9. Not necessarily in the sequence order.
    So the number are arranged randomly like this: 1,x1,x2,x3,x4,x5,x6,x7,x8,x9.
    We know that sum of numbers from 1 to 10 will add upto 55.
    so we will prove it in a negative way, if any of the groups above like (x1+x2+x3) or (x4+x5+x6) or (x7+x8+x9) will add up to < = (less than or equal to) 17. Then the sum 1+x1+...x9 will be <=52 which is wrong.
    So atleast one of the section should be greater than 17. (Hence proved 😀 )
  • Prashanth_p@cchi
    Prashanth_p@cchi
    English-Scared
    I agree...... I understood it wrong!
