  • Are mild steel tanks suitable for storing phthalate plasticizers like DOP?
    Yenyen
    Member
    Updated: Oct 26, 2024
    Views: 1.0K
    DOP is a plasticzer used to make PVC soft.I wish to know from fellow CEans, having chemical engineering expertize, if DOP can be stored in ms tanks without any rust contamination inside the tank.The exterior of the tank will be painted with ant-corrosive epoxy paint.😕
    Di Octyl Phthalate is sold in bulk in iron drums. MS tank should be suitable. However, I would suggest that SS, Polyethylene or poly propylene be used. The containers must be air tight sealed. Ingress of moisture should be prevented.
    Since DOP is combustible, it may be advisable to have a nitrogen blanket above the liquid level to avoid fire hazards.
  • Yenyen
    MemberMay 20, 2012
    bioramani
    Hi! Bioramani,
    Thank you for your suggestions regarding the different materials of construction available for storage of DOP plasticizer.I appreciate your quick response to my query.
    Regards,
    Dr. N. Nanda Kumar
  • ben11c
    MemberAug 7, 2012
    Mild Steel Tanks are very well suited for storing phtalate plasticizers
