Application to power on/off light automatically
Hi ,
I am new to this forums , so HI to all . I am a software developer and just started my journey in electronics side .
I had this particular idea which I want to do for my project .
IDEA : Problem statement : In my college every room has fans and light which is powered with normal switches. People when leaving the class don't switch off the fans and lights when leaving the classroom
Solution : I wanted to develop a software which will recognize when the classroom is empty and will switch off the lights as soon as no one is there .
It will have three components :
1. Sensor : This will detect that there are no people in the room and send a signal to the system
2. Software system : Which is responsible for taking in INPUT from the sensor do the processing and send either signal ON/OFF command in some form to the electrical main
3. Main Circuit : This circuit should understand the software command and convert it to signal of some form which makes circuit switch off and switch on
MY PROBLEM :
I am not able to figure out two things .
1. What circuit should I use which can understand a software command and convert to signal ?
2. How can this circuit switch off the power?
I will be greatfull , If somebody can guide if not give proper solution ![[โIMG]](proxy.php?image=http%3A%2F%2Fforum.allaboutcircuits.com%2Fimages%2Fsmilies%2Fsmile.gif&hash=007d0e78e2b03c7064194620c36ba346)
