You sure you want a nylon string guitar? It's actually called a classical guitar and you'll have to play it using your finger nails.
But if you've fixed your mind on a nylon string guitar, go with Yamaha C-40 model; should cost you around INR 6k-7k [not at all sure of prices in Delhi 😀 ]
Happy Guitaring!
The_Big_K
You sure you want a nylon string guitar? It's actually called a classical guitar and you'll have to play it using your finger nails...
Can't I use a pick to play it?? As I said I'm a n00b, so I don't really have a lot of idea. I read about this in a website (that new players should buy nylon string guitars). The last time I started learning the guitar, my fingers used to hurt a lot!!
I can change the strings to steel ones, once i get the hang of it!!
Well, let me explain -
Nylon string guitar is different from the normal steel-string guitar. Nylon string guitar is played with fingernails and it's an altogether different style of playing it. Even the construction of nylon string guitar is different. The fret-board is wider and the strings are placed bit farther from each other. In order to play the classical guitar, you'll have to hold it in a different position. Normally ( 😀 ) you won't use a pick to play the nylon string guitar.
The regular guitar {as we'll call it} will have steel strings and may have different models. Steel strings don't hurt - trust me. Assuming you play right handed, the right hand fingers are only used to press the strings over the frets. You will pluck the strings using your left hand with a pick [plectrum].
If you are complete newbie, I'd say go ahead with the steel string guitar. Nylon string guitar is 100 times more difficult to play. So begin with the regular guitar and once you are ready for the classical one; go ahead with it.
Oh, it's going to require lot of patience. Remember "Played it till my fingers bled..." 😀 . There's no other way, unfortunately.
Update: Look here for various positions: https://www.guitarprinciples.com/Guitar_Technique/sitting.htm
Thanks for the info!! I'll go in for a steel string. Any suggestions as to which guitar should I buy?? And what to look for in a guitar before buying?? Like areas which are most likely to have defects..
I firmly believe that a beginner should go with a basic f-cut model of medium size. If not, just hold the guitar in playing position and find out how comfortable you are with it. Go with the one that's most comfortable to you.
Check for the distance between the strings & the freboard. Can you press the strings over the frets easily? Can you play the higher notes effortlessly?
Also, check if the arm of the guitar is straight.
Rest of the tips - over to CEan - Gohm 😀
Another tip: use light or extra light gauge strings, and lower the string height if you can by adjusting the bridge. The last will depend on how the guitar is built, and it's probably best to get a shop to modify it and set up the action.
If you start out with normal gauge steel strings which usually means only the B and E treble strings are plain, the rest are wound, your fingers take longer to toughen up. Light strings are easier to fret. Also get some fretboard lube (there are silicon products to ease up those slides), practise a lot and after a few weeks the ends of your fretting fingers will have callouses.
Thanks for the tips!! I'll keep them in mind..
gohm
Member •
Jul 24, 2009
yeah, start out with an economical basic guitar. You can invest in an expensive high quality one later when your skills can take advantage of the better quality and you know you will continue playing. Either variety of guitar is good as you probably do not know yet what style of music you will enjoy playing. practice, practice, practice. Start with open chords, basic scales and strumming technique. Lessons will help you learn faster and avoid picking up bad habits. It is an easy instrument to learn, hard to master.
Once I am proficient enough, I'd probably start playing classic rock, metal. Like floyd, sabbath, priest, clapton, megadeth,etc..
PS - There's a (legally) free alternative to guitar pro, its called tuxguitar. you can play gp3,gp4 and gp5 files on it. It works on windows, linux, mac, bsd..heck, you don't even have to download it..you can use it online (through java)!!
:$ Renewed my interest in purchasing one of my own. A hobby! I was told to get one :! Apparently, surfing the net, spending time on CE, FB and watching movies and various other programmes aren't hobbies ? In all honesty, I do love love love my music this would be the perfect way to keep that passion alive. I shall check out a few stores myself, and hopefully take a friend along.. as I am a complete novice. I don't want an overeager sales person to sell me an electric guitar which I cannot house or play with, but would be persuaded to buy for the aesthetics and general cool factor :$
@black_rose
what kind of music do you play (or are gonna play)??
Hello guys.... I am learning guitar since last year ...
Ask me if you have doubts...I am not a master yet but can help you..... 😎
sandy1988
Appearing for Trinity Certification?
I'm taking the Grade III exam.
I dont know about any certification ...
Please inform me about it ...
my email ID is : < we won't email you>
thanks in advance .. 😀
Why do you want us to contact you through email? Post everything here on forums and everyone benefits from the discussions.
Check out Trinity College Certifications in Rock Guitar.
