@shaktivesh-H2OKXe • Aug 20, 2012
Dude, I'm also facing same problem if you found any solution please tell me, I'm stuck here in my project due to this error "no data sets on file".
@zaveri-5TD6Sk • Aug 20, 2012
Hey for that you got to enter the values of young's modulus and poison's ratio for the material of the cricket ball. check if you have done that.
This process is done prior to modeling and meshing, using the "material models" option. -
@shaktivesh-H2OKXe • Aug 21, 2012
Ya, I've defined material model for both target and projectile. I've followed one tutorial given by Ansys "Container is falling onto the floor". Still it show error "no data sets on file" and then show "Load set not found on result file XYZ.rst".
I don't know how to rectify it. -
@zaveri-5TD6Sk • Aug 21, 2012
Than maybe you need to recheck your meshing and the the load setting(displacement).
