  • ANSYS 12 installation problem?
    uvijayengg
    uvijayengg
    @uvijayengg-xILBXy
    Updated: Oct 24, 2024
    Views: 1.1K
    I was install Ansys 12. i get below Message "Error :Ansys execution Failed!
    If This was Distributed ANSYS job, Verify that your MPI software is installed correctly and is in your PATH , check your environment setting or check for an invalid command line option.. OS win 7, 64 Bit, Dell laptop how do solve this help me?
  • PraveenKumar Purushothaman
    MemberJul 14, 2011
    Go to Control Panel, System. Click on Advanced Tab and click on Environment Variables. Edit the PATH in the list below to the exact path of the Ansys program installation directory. Hope this helps you. 😀
  • uvijayengg
    MemberJul 15, 2011
    Thank you Mr.praveenscience
    MemberJul 16, 2011
    Sure... Do revert back with issues if any... 😀
  • deer
    MemberFeb 27, 2012
    hi, I have the same problem with Ansys 12 (win 7 64-bit, Dell laptop). when I try to edit PATH then i get message that there cannot be find ansinfo.dll. can you help me with this?
    MemberFeb 27, 2012
    deer
    You need to copy that file to your Windows\System32 directory... 😀 Try and say if it worked! 😀
  • Muhammad Mohsin
    MemberAug 9, 2015
    sir can you please tell whether I can get ansys 12 64 bit free?
    I have 32 bit version
  • Monu kumar
    MemberAug 24, 2015
    I have dell laptop inspiring model & now m getting problem while viewing pics by clicking next and it shows error serrogate problem. So what's the solution for that.
