Android in Water ! FML ! (Help)
Abhishek Rawal
@abhishek-fg9tRh โ€ข Oct 14, 2024
Let me make it short,
I dropped my Android in water & spontaneously I picked it up from it & opened it up.
I am unable to open entire as i don't have some tools.
Will my Android will start working once it gets soaked or it's dead ?
Need help/Guidance !
    @anoop-kumar-GDGRCn • Mar 14, 2013
    You can just hope it would be functional again.
    Battery removal asap might save. and insert the battery only when you sure there is no moisture left in phone.
    you can use hair dryer and then left the phone for 2-3 days to dry of.
    @thebigk • Mar 14, 2013
    Rice is a great moisture absorbant and you should remove the back lid and keep the phone sinked in a jar of rice for two days. The rice should absorb the moisture from the phone's components.
    Thread moved to gadgets section.
    @abhishek-fg9tRh • Mar 14, 2013
    Any chance of permanent damage to phone ?
    Troll_So_HardAny chance of permanent damage to phone ?
    Let's hope not, but yep - there are high chances of damage. I had to take my Note II to the service center just to fix the moisture. First dry the phone and then make sure you use a silica gel or rice to take care of the moisture. Do let us know how it works. I'm afraid dropping the phone in water also voids the warranty.
    The_Big_KI'm afraid dropping the phone in water also voids the warranty.
    Now that's awesome ! ๐Ÿ˜ก
    Root + Custom ROM + Wet Android == Okay, I am pwned !
    Hope my cell resurrects soon.
    Thanks for the tips #-Link-Snipped-# & #-Link-Snipped-#
    With custom ROM, you basically said goodbye to warranty. I hope you have a backup of your important data. That basically reminds me that I need to fire up Kies and backup my phonebook. Everything else can be downloaded from Flipkart ๐Ÿ˜›
  • Anand Tamariya
    @anand-tamariya-DnfjEX • Mar 14, 2013
    Modern electronics devices are very sturdy. Being wet shouldn't cause permanent damage in most cases, albeit make sure you don't run the device in that state (you want to avoid short circuit). I dropped my iPod in water once. Once it was completely dry, it worked fine (it's been four years now!).
    #-Link-Snipped-# - I think it's time for you to adopt the Xperia Z waterproof mobile. Check out this video -
    The_Big_K#-Link-Snipped-# - I think it's time for you to adopt the Xperia Z waterproof mobile. Check out this video -
    [โ€‹IMG]
    ๐Ÿ˜›
  • babumoshaaye
    @babumoshaaye-aOuwuO • Mar 15, 2013
    Xperia Go and Xperia Sola are also waterproof smartphones under 18K. They have good specs too.
    @abhishek-fg9tRh • Mar 15, 2013
    Kaustubh KatdareDo let us know how it works.
    Finally Android starts --> Thanks to ya'all !
    Speaker is dead,everything else is working.
