Amplitude modulation Problem
Rakib Ansary
@rakib-ansary-RPtZ7V โ€ข Oct 26, 2024
Not sure if this is the right place to ask, but I am stuck with an Electronic Communication problem.
A 1000-kHz carrier is simultaneously modulated with 300-Hz, 800-Hz and 2-kHz audio sine waves. What will be the frequencies present in the output?
I don't need an exact answer. Just a pointer in the right direction would be hugely appreciated. Thanks
  • RRITESH
    @rritesh-rEBJ6G • Dec 27, 2011
    Read this #-Link-Snipped-#
    As i remember the max side band freq will be Fmax= 1000+300 and Fmin = 1000-300
  • Sagar07
    @sagar07-LecI1i • Dec 28, 2011
    i think, if its amplitude modulation problem(as you say in the title), frequency of the output will be frequency of carrier itself which is 1000 Hz.
  • silverscorpion
    @silverscorpion-iJKtdQ • Dec 28, 2011
    ^^ Yes.
    If amplitude is modulated, then there will be different amplitudes at various times in the output, but the frequency of the output will be the same as the carrier frequency.
  • Arnav Joshi
    @arnav-joshi-faqqJ8 • Jan 24, 2012
    Sagar07i think, if its amplitude modulation problem(as you say in the title), frequency of the output will be frequency of carrier itself which is 1000 Hz.
    silverscorpion^^ Yes.
    I am afraid this is not correct. Amplitude modulation does not mean that the output frequency will be same as carrier frequency. Since carrier frequency is usually very large than signal frequency , the sidebands produced have frequency very near to that of carrier. What you say about the amplitude at different times is of right though.
    Each sine wave applied at input of Amplitude Modulator will produce two side bands around the carrier. For instance the sine wave has frequency f[sub]1[/sub] and carrier has frequency f[sub]c[/sub]. Output will have the frequency f[sub]c[/sub] - f[sub]1[/sub] as well as f[sub]c[/sub] + f[sub]1[/sub] and if carrier is not suppressed f[sub]c[/sub] will also be present.
    In this problem three sine waves are applied, each will produce two side bands.
    Of course I am assuming standard AM. There are forms of AM in which carrier and/or one of the side bands may be suppressed.(<a href="https://en.wikipedia.org/wiki/Modulation#Analog_modulation_methods" target="_blank" rel="nofollow noopener noreferrer">Modulation Analog Modulation Methods</a>)
    As to why two side bands are produced ? Expand the AM signal cos(2pi f[sub]c[/sub]t )cos(2pi f[sub]1[/sub]t ) by the rule
    cos(A)cos(B) = 1/2( cos(A+B) + cos(A-B) )
  • Eng.Micah
    @engmicah-xvj5Zc • Feb 17, 2012
    frequency will be same for both output and input. the lower and upper side bands will bring the diffferent in amplitude.
