  • Alternative fuels for the internal combustion engine?
    jbivy
    jbivy
    @jbivy-IM1P5B
    Updated: Nov 29, 2011
    Views: 1.6K
    So I have transplanted a 2003 hyundai 2.7L v6 and 4speed auto transaxle into the back of a 1939 plymouth touring. Running gasoline is just far too passe. Ive debated running propane. Building a custom tank for under the hood, but again, thats too common. Alcohol is a possibillity, but still overly done. Perhaps a hydrogen/oxygen engine?
    What are your thoughts?
  • Gurjap
    MemberDec 25, 2011
    whatever you do, avoid hydrogen. The hydrogen embrittlement problem for metals is huge and will probably cause catastrophic failures one day.
    try running it on coal dust, or gasified coal, or producer gas
    [took this from Wikipedia "2C + O2 + N2 → 2CO+N2
    The nitrogen in the air remains unchanged and dilutes the gas, giving it a very low calorific value. After "scrubbing", to remove tar, the gas may be used to power ...spark ignited engines (where 100% petrol fuel replacement is possible) or diesel internal combustion engines (where 40% - 15% of the original diesel fuel is still used to ignite the gas).]
    Or use water-gas shift reaction to make CO and H2 from coal and steam. Or burn the coal partially, turn it into CO and run the engine on that. Crazy, yeah, but what the heck
  • veereshsg
    MemberDec 25, 2011
    There is a need to find an alternate fuel.
    I have tried HOME[Honge Oil Methyl Ester] in combination with Diesel. I got optimum results for 15% of HOME mixed with Diesel, without much change in the Mechanical efficiency and without modifying the engine.
    Honge Oil is a non edible oil. Give it a try.
