AI Project Help
ANAND KRISHNAN
@anand-498CtV โ€ข Oct 26, 2024
Can any one send me the abstract for "Build a virtual reality system where people can interact with virtual objects or creatures without the need of headsets, goggles, or any special sensing equipment."
AND
Abstract for "Use the concepts in machine-learning technology to develop an Internet soft-bot (software robot), a customizable and (moderately) intelligent assistant for Internet access. It should accept input in a high-level language, generate and execute what is needed by the user on its own."
    @ramani-VR4O43 • Apr 21, 2016
    K.ANAND KUMARCan any one send me the abstract
    An abstract is a short summary of a research paper, thesis or an proposal. It is generated after the full item is written. If you can give the complete article, many here can give you the abstract.
  • ANAND KRISHNAN
    @anand-498CtV • Apr 22, 2016
    Sir I got that topics from this link
    <a href="https://www.crazyengineers.com/threads/artificial-intelligence-project-ideas-topics-for-engineering-students.58508">Artificial Intelligence Project Ideas/Topics For Engineering Students</a>
    @ramani-VR4O43 • Apr 22, 2016
    K.ANAND KUMARSir I got that topics from this link
    That is good. What sort of help are you looking for from CEans? If you specify what you want many here will help.
    Have a look at this DIY tutorial. May start you in the right direction:
    Some more diverse projects:
  • ANAND KRISHNAN
    @anand-498CtV • May 15, 2016
    Can any one tell me about how to compare two audio file using java.
  • pratap singh, upendra
    @pratap-singh-6xlmve • May 16, 2016
    K.ANAND KUMARcompare two audio file using java.
    Compare in what sense?
    Are you trying to ascertain if they are same files or of same format, or having same content or anything of that sort?
  • ANAND KRISHNAN
    @anand-498CtV • May 16, 2016
    proffyCompare in what sense?
    yes but should match voice in any language if the input is.
    K.ANAND KUMARyes but should match voice in any language if the input is.
    Be as descriptive as possible. Your response is way too ambiguous to be answered precisely.
    @ramani-VR4O43 • May 16, 2016
    proffyYour response is way too ambiguous to be answered precisely.
    You are right. There are some white papers like this on language identification:
    Would that be of any use? May be this is a commercial product and not a tool for developers. I am way off axis in this.
  • ANAND KRISHNAN
    proffyBe as descriptive as possible. Your response is way too ambiguous to be answered precisely.
    I want to match the voices, contents if possiable and find that they are of same persons ,identical in terms of percentages like 80% match,60% match etc
  • ANAND KRISHNAN
    I want voice matching program in java
    @pratap-singh-6xlmve • May 18, 2016
    K.ANAND KUMARI want to match the voices, contents if possiable and find that they are of same persons ,identical in terms of percentages like 80% match,60% match etc
    Now you are talking.....
    See, the problem that you described is that of speaker identification, an area in speech technology. For this, various tool kits are available (though they may not be written in Java). Try pocket sphinx. For this,you require a Linux machine to perform your simulations.
    For more information visit #-Link-Snipped-#
