After 'e-diesel', Audi develops 'e-benzin' - a green fuel from plants
Coral Jain
@coral-jain-PzrSjf โ€ข Oct 26, 2024
Last month, Audi surprised the whole world when they claimed that they produced diesel from carbon dioxide and water, naming it as <a href="https://www.crazyengineers.com/threads/audi-e-diesel-is-produced-from-water-and-carbon-dioxide.80259">Audi e-Diesel Is Produced From Water And Carbon Dioxide</a> But for cars operating on gasoline as fuel, Audi has come up with an innovative technique. This time Audi has claimed that they've developed gasoline from plants. Known to be 'e-benzin', this synthetic fuel has been developed in France by Audi's project partner Global Bioenergies. The high grade fuel obtained from the plants is free of benzene and sulphur and produces no dangerous smoke. Marking this invention as the historic innovation of all time, Global Bioenergies' CEO Marc Delcourt proclaimed that they are aiming to add 'green' in the world that requires green-ness.
imageโ€‹
The work began in 2014 by setting up a fermentation unit to produce gaseous isobutane (a raw material obtained from petrochemical industries) from corn-derive glucose (a kind of biomass sugar). The material was passed through conditioning and purification unit and the stored under heavy pressure in the form of liquid. Some part of the final product obtained was converted into isooctane fuel which produced hundred octane gasoline.
However, according to German automaker, the isooctane obtained is currently being used to improve quality of the existing fuel, but the company believes that it can be used as a stand alone fuel in the near future. In future, e-benzin will be tested in vehicles after performing some tests on conduct engine and fuel composition.
imageโ€‹
The next big aim of both the companies is to produce gasoline from only carbon dioxide, sunlight, water and hydrogen. Audi is building a new demonstration plant to produce isooctane and high-purity isobutane in Germany, that will be ten times as big as that of France (shown above).
Do you find this new innovative way of producing gasoline worthy of being an alternative green fuel? Share your thoughts with us in the comments section below.
source: #-Link-Snipped-#
  • Shashank Moghe
    @shashank-94ap1q • May 26, 2015
    This part,
    is confusing! Does it mean that iso-octane is e-benzin?
  • Coral Jain
    @coral-jain-PzrSjf • May 26, 2015
    Iso-octane obtained from the condensation and purification of isobutane can eventually produce gasoline. This product i.e. Gasoline is known as 'e-benzin' because it is free from benzene and other harmful gases. E-benzine has not been tested for tis complete use. So, researchers are using isooctane currently.
  • Sheikh Aamir Farhan
    @sheikh-aamir-farhan-MV6w8S • May 26, 2015
    i loved this new innovative way of producing fuel
    since, the world today is in great need of such an innovation,yhis may give a mass impact to fuel demand and supply.
  • Coral Jain
    Sheikh Aamir Farhani loved this new innovative way of producing fuel
    Indeed. Such an amazing innovation from renewable sources of energy.
  • Shashank Moghe
    @shashank-94ap1q • May 27, 2015
    Coral JainIso-octane obtained from the condensation and purification of isobutane can eventually produce gasoline. This product i.e. Gasoline is known as 'e-benzin' because it is free from benzene and other harmful gases. E-benzine has not been tested for tis complete use.
    Great!
    Coral JainSo, researchers are using isooctane currently.
    Well, iso-octane is the representative hydrocarbon for Gasoline with a 100% octane rating. The gasoline we use in our vehicles is a blend of several other hydrocarbons.
  • Coral Jain
    @coral-jain-PzrSjf • May 27, 2015
    โ€‹
    This part,
    " However, according to German automaker, the isooctane obtained is currently being used to improve quality of the existing fuel, but the company believes that it can be used as a stand alone fuel in the near future. "
    Explains that neither isooctane nor e-benzin has been put to use alone. Isooctane is in use right now to make better quality. E-benzin would be used in future. Isooctane would be use along with other hydrocarbons right now. In future, company will test e-bezin.
  • Shashank Moghe
    Coral JainIso-octane obtained from the condensation and purification of isobutane can eventually produce gasoline. This product i.e. Gasoline is known as 'e-benzin' because it is free from benzene and other harmful gases. E-benzine has not been tested for tis complete use. So, researchers are using isooctane currently.
    This was your response, which as you said in the previous comment, is not correct. That is all I pointed out since that last statement is confusing.
  • Shashank Moghe
    Also, it would help if you mentioned e-benzin == iso-octane. The introduction of these two terms is overlapping and hence confusing.
  • Coral Jain
    Shashank MogheAlso, it would help if you mentioned e-benzin == iso-octane. The introduction of these two terms is overlapping and hence confusing.
    But both are not the same kind of hydrocarbons. Gasoline is obtained from Isooctane. Gasoline obtained from plants is e-benzin.
  • Coral Jain
    I am sure you are getting the points I am trying to make. ๐Ÿ˜€
  • Shashank Moghe
    Two hydrocarbons are the same as long as they have the same chain structure and same no of C & H atoms. What can differ is the way they are produced, which is different in this case. The hydrocarbon is still the same, iso-octane.
    Gasoline is a blend of several hydrocarbons and iso-octane is a major component of that blend, providing essential anti-knock properties to that blend.
    E-benzin is pure iso-octane produced synthetically (not from petroleum), as per the link.
