@akhil-c-joy-rhsVkZ • Jan 19, 2016
Hi ashusingh,
Kindly find some of the MATLAB projects for Communication System.
1. Achieving Joint Diversity in Decode-and-Forward MIMO Relay Networks with Zero-Forcing Equalizers
2. Multi-Dimensional Graph-Based Soft Iterative Receiver for MIMO-OFDM
3. Turbo Multi-User Detection for OFDM/SDMA Systems Relying on Differential Evolution Aided Iterative Channel Estimation
4. LLR Approximation for Wireless Channels Based on Taylor Series and its Application to BICM With LDPC Codes
5. Dynamic Resource Allocation in MIMO-OFDMA Systems with Full-Duplex and Hybrid Relaying
6. 3D MIMO-OFDM Channel Estimation
7. Clipping Noise in OFDM-Based Optical Wireless Communication Systems
8. Joint Sensing Adaptation and Resource Allocation for Cognitive Radio with Imperfect Sensing
9. Low-Complexity Detection of Full-Rate SFBC in BICM-OFDM Systems
10. Performance of Diversity Combining ARQ Error Control in a TDMA SC-FDE System
11. Optical CDMA-Based Fiber-Radio Networks with Improved Power Efficiency
12. Accurate Analysis of Double-Weight Optical CDMA With Power Control
13. Expowave: An RFID Anti-Collision Algorithm for Dense and Lively Environments
14. Low-Complexity Multi-Stream Space-Time CodesรขยยPart II: Unitary-Transform Codes
15. Low Complexity X-EMS Algorithms for Nonbinary LDPC Codes
Kindly find the attached list from another project center.
PS: I strongly recommend to use this topics as a reference and download a IEEE paper from the college. To do it yourself. I don't recommend any of these project centers and I am not liable for any actions or consequences.๐ -
ashusingh OP
@ashusingh-5QPU6L • Jan 21, 2016
hi akhil..i have seen the list attached..can u guide me with an institute which can help me in doing the project in matlab only.
the topic is :
WAVELET BASED ECG STEGANOGRAPHY FOR PROTECTING PATIENT CONFIDENTIAL INFORMATION IN POINT-OF-CARE SYSTEMS -
@akhil-c-joy-rhsVkZ • Jan 22, 2016
Hi Ashusingh,
Even though its software project; For project discussion you need to go there. So Kindly check in your locality for the institutions. All the best.
PS: For MATLAB Project version is really important because some of library files will not be supported older version. Kindly check with you college for their MATLAB version. Also check whether you can able to install and run the system.
