ACI's Manual of Concrete Practice
Manual of Concrete Practice 2005
ACI's Manual of Concrete Practice (MCP) is the most comprehensive concrete reference set available. It contains all of the widely used ACI concrete and masonry code requirements, specifications, guides and reports. Whether you're searching for information about code requirements, deflection, cracking, durability problems, temperature control, nondestructive testing, or hundreds of other topic areas, the MCP can help you find what you need.
Contents
CODE | DOCUMENT
TOC Table of Contents
104-71 Preparation of Notation for Concrete
116R-00 Cement and Concrete Terminology
117-90 Standard Specifications for Tolerances for Concrete Construction and Materials
117R-90 Commentary on Standard Specifications for Tolerances for Concrete Construction and Materials
121R-04 Quality Management System for Concrete Construction
122R-02 Guide to Thermal Properties of Concrete and Masonry Systems
124.2R-94 The Mercer Mile Buildings
126.3R-99 Guide to a Recommended Format for Concrete in a Materials Property Database
201.1R-92 Guide for Making a Condition Survey of Concrete in Service
201.2R-01 Guide to Durable Concrete
207.1 R-96 Mass Concrete
207.2R-95 Effect of Restraint, Volume Change, and Reinforcement on Cracking of Mass Concrete
207.3R-94 Practices for Evaluation of Concrete in Existing Massive Structures for Service Conditions
207.4R-93 Cooling and Insulating Systems for Mass Concrete
207.5R-99 Roller Compacted Mass Concrete
209R-92 Prediction of Creep, Shrinkage, and Temperature Effects in Concrete Structures
210R-93 Erosion of Concrete in Hydraulic Structures
210.1 R-94 Compendium of Case Histories on Repair of Erosion-Damaged Concrete in Hydraulic Structures
211.1-91 Standard Practice for Selecting Proportions for Normal, Heavyweight, and Mass Concrete
211.2-98 Standard Practice for Selecting Proportions for Structural Lightweight Concrete
211.3R-02 Guide for Selecting Proportions for No-Slump Concrete
211.4R-93 Guide for Selecting Proportions for High-Strength Concrete with Portland Cement and Fly Ash
211.5R-01 Guide for Submittal of Concrete Proportions
212.3R-04 Chemical Admixtures for Concrete
212.4R-04 Guide for the Use of High-Range Water-Reducing Admixtures (Superplasticizers) in Concrete
213R-03 Guide for Structural Lightweight Aggregate Concrete
214R-02 Evaluation of Strength Test Results of Concrete
214.4R-03 Guide for Obtaining Cores and Interpreting Compressive Strength Results
215R-74 Considerations for Design of Concrete Structures Subjected to Fatigue Loading
216R-89 Guide for Determining Fire Endurance of Concrete Elements
216.1-97 Standard Method for Determining the Fire Resistance of Concrete and Masonry Construction Assemblies
221R-96 Guide for Use of Normal Weight and Heavyweight Aggregates in Concrete
221.1R-98 State-of-the-Art Report on Alkali-Aggregate Reactivity
222R-01 Protection of Metals in Concrete Against Corrosion
222.1-96 Prov Stand Test Meth for Water-Soluble Chloride Avail for Corr of Embedded Steel in Mortar & Cone Using the Soxhlet
222.2R-01 Corrosion of Prestressing Steels
222.3R-03 Design and Construction Practices to Mitigate Corrosion of Reinforcement in Concrete Structures
223-98 Standard Practice for the Use of Shrinkage-Compensating Concrete
224R-01 Control of Cracking in Concrete Structures
224.1 R-93 Causes, Evaluation, and Repair of Cracks in Concrete Structures
224.2R-92 Cracking of Concrete Members in Direct Tension
224.3R-95 Joints in Concrete Construction
225R-99 Guide to the Selection and Use of Hydraulic Cements
228.1 R-03 In-Place Methods to Estimate Concrete Strength
228.2R-98 Nondestructive Test Methods for Evaluation of Concrete in Structures
229R-99 Controlled Low-Strength Materials
230.1 R-90 State-of-the-Art Report on Soil Cement
232.1 R-00 Use of Raw or Processed Natural Pozzolans in Concrete
232.2R-03 Use of Fly Ash in Concrete
233R-03 Slag Cement in Concrete and Mortar
234R-96 Guide for the Use of Silica Fume in Concrete
301-99 Specifications for Structural Concrete
301M-99 Specifications for Structural Concrete
SP-15(99) Field Reference Manual
302.1 R-04 Guide for Concrete Floor and Slab Construction
303R-04 Guide to Cast-in-Place Architectural Concrete Practice
303.1-97 Standard Specification for Cast-in-Place Architectural Concrete
304R-00 Guide for Measuring, Mixing, Transporting, and Placing Concrete
304.1 R-92 Guide for the Use of Preplaced Aggregate Concrete for Structural and Mass Concrete Applications
304.2R-96 Placing Concrete by Pumping Methods
304.3R-96 Heavyweight Concrete: Measuring, Mixing, Transporting, and Placing
304.5R-91 Batching, Mixing, and Job Control of Lightweight Concrete
304.6R-91 Guide for the Use of Volumetric-Measuring and Continuous-Mixing Concrete Equipment
305R-99 Hot Weather Concreting
306R-88 Cold Weather Concreting
306.1-90 Standard Specification for Cold Weather Concreting
307-98 Design and Construction of Reinforced Concrete Chimneys
307R-98 Commentary on Design and Construction of Reinforced Concrete Chimneys
308R-01 Guide to Curing Concrete
308.1-98 Standard Specification for Curing Concrete
309R-96 Guide for Consolidation of Concrete
309.1 R-93 Behavior of Fresh Concrete During Vibration
309.2R-98 Identification and Control of Visible Effects of Consolidation on Formed Concrete Surfaces
309.3R-92 Guide to Consolidation of Concrete in Congested Areas
309.5R-00 Compaction of Roller-Compacted Concrete
311.1R-99 ACI Manual of Concrete Inspection
311.4R-00 Guide for Concrete Inspection
311.5-04 Guide for Concrete Plant Inspection and Testing of Ready-Mixed Concrete
313-97 Standard Practice for Design and Construction of Concrete Silos and Stacking Tubes for Storing Granular Materials
313R-97 Comm on Standard Practice for Design and Construction of Concrete Silos and Stacking Tubes for Storing Granular Matls
315-99 Details and Detailing of Concrete Reinforcement
SP-66(04) ACI Detailing Manual
318-05/318R-05 Building Code Requirements for Structural Concrete and Commentary
318M-02 /318RM-02 Building Code Requirements for Structural Concrete and Commentary (metric)
SP-71(02) ASTM Standards in ACI 318
325.3R-85 Guide for Design of Foundations and Shoulders for Concrete Pavements
325.6R-88 Texturing Concrete Pavements
325.10R-95 State-of-the-Art Report on Roller-Compacted Concrete Pavements
325.11R-01 Accelerated Techniques for Concrete Paving
325.12R-02 Guide for Design of Jointed Concrete Pavements for Streets and Local Roads
330R-01 Guide for Design and Construction of Concrete Parking Lots
330.1-03 Specification for Unreinforced Concrete Parking Lots
332R-84 Guide to Residential Cast-in-Place Concrete Construction
334.1 R-92 Concrete Shell Structures Practice and Commentary
336.1-01 Specification for the Construction of Drilled Piers
336.2R-88 Suggested Analysis and Design Procedures for Combined Footings and Mats
336.3R-93 Design and Construction of Drilled Piers
341.2R-97 Seismic Analysis and Design of Concrete Bridge Systems
343R-95 Analysis and Design of Reinforced Concrete Bridge Structures
345R-91 Guide for Concrete Highway Bridge Deck Construction
345.1 R-92 Routine Maintenance of Concrete Bridges
345.2R-98 Guide for Widening Highway Bridges
346-01 Specifications for Cast-in-Place Concrete Pipe
347-04 Guide to Formwork for Concrete
SP-4(95) Formwork for Concrete
349-01/349R-01 Code Requirements for Nuclear Safety Related Concrete Structures and Commentary
349.1 R-91 Reinforced Concrete Design for Thermal Effects on Nuclear Power Plant Structures
349.2R-97 Embedment Design Examples
349.3R-02 Evaluation of Existing Nuclear Safety-Related Concrete Structures
350-01/350R-01 Code Requirements for Environmental Engineering Concrete Structures and Commentary
350.1/350.1 R-01 Tightness Testing of Environmental Engineering Concrete Structures and Commentary
350.2R-04 Concrete Structures for Containment of Hazardous Materials
350.3/350.3R-01 Seismic Design Guide for Liquid-Containing Concrete Structures and Commentary
350.4R-04 Design Considerations for Environmental Engineering Concrete Structures
351.1R-99 Grouting between Foundations and Bases for Support of Equipment and Machinery
351.2R-94 Foundations for Static Equipment
351.3R-04 Foundations for Dynamic Equipment
352R-02 Recommendations for Design of Beam-Column Joints in Monolithic Reinforced Concrete Structures
352.1 R-89 Recommendations for Design of Slab-Column Connections in Monolithic Reinforced Concrete Structure
355.2-04/355.2R-04 Evaluating the Performance of Post-Installed Mechanical Anchors in Concrete and Commentary
357R-84 Guide for the Design and Construction of Fixed Offshore Concrete Structures
357.2R-88 State-of-the-Art Report on Barge-Like Concrete Structures
358.1 R-92 Analysis and Design of Reinforced and Prestressed-Concrete Guideway Structures
359-01 Code for Concrete Containments
360R-92 Design of Slabs on Grade
362.1 R-97 Guide for the Design of Durable Parking Structures
362.2R-00 Guide for Structural Maintenance of Parking Structures
363R-92 State-of-the-Art Report on High-Strength Concrete
363.2R-98 Guide to Quality Control and Testing of High-Strength Concrete
364.1 R-94 Guide for Evaluation of Concrete Structures Prior to Rehabilitation
365.1 R-00 Service-Life PredictionâState-of-the-Art Report
371R-98 Guide for the Analysis, Design, and Construction of Concrete-Pedestal Water Towers
372R-03 Design and Construction of Circular Wire- and Strand-Wrapped Prestressed Concrete Structures
373R-97 Design and Construction of Circular Prestressed Concrete Structures with Circumferential Tendons
408R-03 Bond and Development of Straight Reinforcing Bars in Tension
408.2R-92 State-of-the-Art Report: Bond under Cyclic Loads
408.3-01/408.3R-01 Splice and Development Length of High Relative Rib Area Reinforcing Bars in Tension and Commentary
421.1R-99 Shear Reinforcement for Slabs
423.3R-96 Recommendations for Concrete Members Prestressed with Unbonded Tendons
423.4R-98 Corrosion and Repair of Unbonded Single Strand Tendons
423.5R-99 State-of-the-Art Report on Partially Prestressed Concrete
423.6-01/423.6R-01 Specification for Unbonded Single Strand Tendons and Commentary
435R-95 Control of Deflection in Concrete Structures
435.7R-85 State-of-the-Art Report on Temperature-Induced Deflections of Reinforced Concrete Members
435.8R-85 Observed Deflections of Reinforced Concrete Slab Systems, and Causes of Large Deflections
437R-03 Strength Evaluation of Existing Concrete Buildings
439.3R-91 Mechanical Connections of Reinforcing Bars
440R-96 State-of-the-Art Report on Fiber Reinforced Plastic (FRP) Reinforcement for Concrete Structures
440.1 R-03 Guide for the Design and Construction of Concrete Reinforced with FRP Bars
440.2R-02 Guide for the Design and Construction of Externally Bonded FRP Systems for Strengthening Concrete Structures
440.3R-04 Guide Test Methods for Fiber-Reinforced Polymers (FRP) for Reinforcing or Strengthening Concrete Structures
440.4R-04 Prestressing Concrete Structures with FRP Tendons
441R-96 High-Strength Concrete Columns: State of the Art
445R-99 Recent Approaches to Shear Design of Structural Concrete
446.1 R-91 Fracture Mechanics of Concrete: Concepts, Models, and Determination of Material Properties
446.3R-97 Finite Element Analysis of Fracture in Concrete Structures: State-of-the-Art
446.4R-04 State of the Art Report on Dynamic Fracture of Concrete
503R-93 Use of Epoxy Compounds with Concrete
503.1-92 Stand Spec for Bonding Hardened Cone, Steel, Wood, Brick, & Other Matls to Hardened Cone w/ a Multi-Comp Epoxy Adhes
503.2-92 Stand Spec for Bonding Plastic Cone to Hardened Cone w/ a Multi-Component Epoxy Adhesive
503.3-92 Stand Spec for Producing a Skid-Resistant Surface on Cone by the Use of a Multi-Component Epoxy System
503.4-92 Standard Specification for Repairing Concrete with Epoxy Mortars
503.5R-92 Guide for the Selection of Polymer Adhesives with Concrete
503.6R-97 Guide for the Application of Epoxy and Latex Adhesives for Bonding Freshly Mixed and Hardened Concretes
504R-90 Guide to Sealing Joints in Concrete Structures
506R-90 Guide to Shotcrete
506.1 R-98 Committee Report on Fiber Reinforced Shotcrete
506.2-95 Specification for Shotcrete
506.3R-91 Guide to Certification of Shotcrete Nozzlemen
506.4R-94 Guide for the Evaluation of Shotcrete
523.2R-96 Guide for Precast Cellular Concrete Floor, Roof, and Wall Units
524R-04 Guide to Portland Cement-Based Plaster
530-05/530R-05 Building Code Requirements for Masonry Structures and Commentary
530.1-05/530.1 R-05 Specification for Masonry Structures and Commentary
533R-93 Guide for Precast Concrete Wall Panels
533.1 R-02 Design Responsibility for Architectural Precast-Concrete Projects
543R-00 Design, Manufacture, and Installation of Concrete Piles
544.1 R-96 State-of-the-Art Report on Fiber Reinforced Concrete
544.2R-89 Measurement of Properties of Fiber Reinforced Concrete
544.3R-93 Guide for Specifying, Proportioning, Mixing, Placing, and Finishing Steel Fiber Reinforced Concre
544.4R-88 Design Considerations for Steel Fiber Reinforced Concrete
546R-04 Concrete Repair Guide
546.2R-98 Guide to Underwater Repair of Concrete
548.1 R-97 Guide for the Use of Polymers in Concrete
548.2R-93 Guide for Mixing and Placing Sulfur Concrete in Construction
548.3R-03 Polymer Modified Concrete
548.4-93 Standard Specification for Latex-Modified Concrete (LMC) Overlays
548.5R-94 Guide for Polymer Concrete Overlays
548.7R-04 Provisional Test Method for Load Capacity of Polymer Concrete Underground Utility Structures
549.1 R-93 Guide for the Design, Construction, and Repair of Ferrocement
549.2R-04 Thin Reinforced Cement Pro ducts: State-of-the-Art
550R-96 Design Recommendations for Precast Concrete Structures
550.1 R-01 Emulating Cast-in-Place Design in Precast Concrete Structures
551R-92 Tilt-Up Concrete Structures
555R-01 Removal and Reuse of Hardened Concrete
ITG-3-04 Report on Bridge Decks Free of Steel Reinforcement
T1.1-01/T1.1R-01 Acceptance Criteria for Moment Frames Based on Structural Testing and Commentary
T1.2-03/T1.2R-03 Special Hybrid Moment Frames Composed of Discretely Jointed Precast and Post-Tensioned Concrete Members and Commentary
ACI Manual of Concrete Practice 2005 - Table of Contents
ACI Manual of Concrete Practice 2005 - Help
[Aditional CD-ROM files]
Enjoy!!
