@thebigk • Feb 4, 2009
durgaI am not sure, but there should be way form which I can acess my windows file system from linux.
any idea?I can access all my windows files from uBuntu without any additional software. There's surely a way ๐ !
durga ch OP@durga-TpX3gO • Feb 4, 2009
I understand that i dont need a software. the data is any ways on my hard drive ๐
but linux file system is different from that of windows right, and i am still unable to get access to windows file sytem
tell me one more thing, i should as well be able to run the softwares what i installed in windows...right? -
@silverscorpion-iJKtdQ • Feb 4, 2009
what do you mean by accessing the file system? I dont get it..
And for using windows based software in LInux, there's a thing called 'Wine' or Windows Emulator. It can be used for windows based software. It doesnt support all types of software, though. Take big games, for instance. They cant be emulated in wine. -
@prasad-aSUfhP • Feb 4, 2009
Durga, what you need to learn is the mount command in linux. It usually goes like this -
$> mount /dev/hda3 /mnt/disk1
Here, /dev/hda3 would be the device (read partition) which you are trying to mount, it can be a cd/dvd drive as well; and /mnt/disk1 is the folder in your linux drive where you are trying to mount that device to.
Note, that this command does not copy all the files to /mnt/disk1 folder, but merely creates a "map" if I may call it so. If you wish to do this permanently, then you need to make a similar entry in your /etc/fstab file.
Biggie, thats why in your Ubuntu, those windows partitions are auto-mounted. Ubuntu is smart enough to configure it for you.
Silverscorpion - for bigger games, try Cedega or Crossover, they are paid, but worth it. Crossover comes for $40 per user per year. I use licensed version, and believe me the Rs. 2000 is money well spent. -
oh, I didnt know that. I'll look out for it. Upto what level of games can it support?
It can go all the way silverscorpion, Cedega can run Medal of Honour genre games as well, even Oblivion (TES4), CS:Source. I have played Warcraft3:FT on Crossover, running MS Office using Crossover. Give it a shot.
silverscorpionwhat do you mean by accessing the file system? I dont get it..
And for using windows based software in LInux, there's a thing called 'Wine' or Windows Emulator. It can be used for windows based software. It doesnt support all types of software, though. Take big games, for instance. They cant be emulated in wine.I was refering to accessing the data on the Harddrive which have been stored while I was a staunch windows user ๐
I want to use those data and softwares when I use Ubuntu -
kidakakaNote, that this command does not copy all the files to /mnt/disk1 folder, but merely creates a "map" if I may call it so. If you wish to do this permanently, then you need to make a similar entry in your /etc/fstab file.
.hey! strange, I use Ubuntu as well:!:
Anyways, so you meant that the data is not duplicated , but instead a path is created to access the data๐ that sounds nice.
and now, I quess i will first look into /etc/fstab to see if there is already the mount command,as even I am using ubuntu ๐ -
hey,
I tried mount
vijayadurga@ubuntu:~/Desktop$ mount /dev/hda2 /Desktop/mount
*mount: only root can do that*
i was under a so called wrong impression that root is the admin, No. not really.
Could some one elaborate? -
@prasad-aSUfhP • Feb 5, 2009
Durga,
Ubuntu by default disables logging in through the root account. It is done so to ensure one higher level of security. What you can do, is use the sudo command.
So try this command -
vijayadurga@ubuntu:~/Desktop$ sudo mount /dev/hda2 /Desktop/mount
That should ask for a password, put in your password. That should do.
