@whats-in-name-KdgM7o • Sep 9, 2010
xxxabhash007I want to know how the 2-D arrays are stored in the memory, exactly how does the compiler look at the 2-D array?๐
Suppose you have declared a array A[4][6],
Then in memory there will be 6 continuous blocks of 4 continuous rows allocated to this.
So if you want to access S,then the address will be A[1][5].
-Correct me if I am wrong. -
@xxxabhash007-zWy2nM • Sep 9, 2010
But I have read in Yashwant's Pointers In C:In memory there are no rows and columns. In memory whether it's a 1-D or 2-D array the elements are stored in one continuous chain.
Memory is in continuous chain,but the way to access it is different.
It can be possible that rows are in continuous form,Eg :
Continuous Memory:
Can be viewed as:
Row 1:[-][-][-][-]Row 2:[-][-][-][-]Row 3:[-][-][-][-]Row 4:[-][-][-][-]So on..
Within computer. -
What is the output?
show(int(*q)[4],int row,int col)
int i,j,*p;
for(i=0;i<row;i++)
p=q+i;
for(j=0;j<col;j++)
printf("%d",*(p+j));
printf("\n");
printf("\n");
where argument *q[4] is receiving the array:
a[3][4]={ {1,2,3,4},
{5,6,7,8},
{9,0,1,6}
row=3 & col=4 -
@xxxabhash007-zWy2nM • Sep 11, 2010
Can anyone give me the output of the program which I have posted.
@anandkumarjha-jzdDMA • Sep 11, 2010
as far as i know the output will be the address of the 3rd row and 4the column element i.e the address of the element 6....if i am wrong then plsss correct me
Can you please give the actual output in double quotes.
@manish-r2Hoep • Sep 11, 2010
It will give you error
ie you cannot convert int *[4] to int * -
@anandkumarjha-jzdDMA • Sep 12, 2010
goyal420It will give you error
ie you cannot convert int *[4] to int *can you please explain the logic behind it
@xxxabhash007-zWy2nM • Sep 13, 2010
@Goyal: There is no such kind of statement "int *[4]" or "int *". Then what are you talking about?
@manish-r2Hoep • Sep 14, 2010
show(int(*q)[4],int row,int col) { int i,j,*p; for(i=0;i<row;i++) { p=q+i; for(j=0;j<col;j++) printf("%d",*(p+j)); printf("\n"); } printf("\n"); }Here p=q+i is invalid statement
Since p is a pointer to array
where as q is pointer to array of columns
you cannot directly store address of q in p
in that case you have to modify this statement as follow
p=&q[0];
with this modification the code will work and will print the array q as its output
