Accelerating content delivery over the Web - Ideas?
This one should tickle the brains of lots of computer science engineers over here.
Apart from using web accelerators (which primarily do the catching), can there be fundamental changes in the way content is delivered over the Internet? I mean, recent introduction of SPDY protocol by Google made me think that the whole working of Internet needs a re-look.
Internet has evolved a lot during last few years and the underlying technologies can be worked upon.
How do you think we can speed up the content delivery on the Internet? Is reworking HTTP the only solution? Think! ๐Ÿ˜
[PS: No 'use faster broadband bullshit in this thread please. Keep the context in mind before you post here.]
  • dragon.rider
    @dragonrider-FTre6v • Nov 13, 2009
    What kind of content do u mean ?
    Big chunks of files eg movies or small file sharing eg. pdf,doc ?
  • sarveshgupta
    @sarveshgupta-txtmu5 • Nov 13, 2009
    Great issue to talk about Biggie
    Was Thinking about same thing these days
    Content Delivery really needs a boost up
    @thebigk • Nov 13, 2009
    Web content is any content. In today's world, most of it is delivered through the hyper text transfer protocol. Now can we really think of ways to improve the speed by making fundamental changes in the way this transfer works.
    This is similar to our earlier discussion on how videos can be transferred over the internet faster on slower connections.
  • Ashraf HZ
    @Ash • Nov 13, 2009
    I'm not much of an expert on the application layer (in which HTTP and SPDY will operate at), but we still have a lot of room for improvement on the physical up to the data link. Efficiencies of routing and better error control algorithms will improve overall data rate. With IPv6 on the way, jumbograms can be used to pack a lot of data in fewer packets.. so one doesn't have to wait longer for the packets to arrive for a given content. How well this works out still depends on the hardware of the networks of course.
  • Guttu
    @guttu-Udy454 • Nov 13, 2009
    I agree with ash. Hardware should be improved. Also moving to grid computing will also help. Developing and implementing better content compression algorithm is another way. Though it won't work for media files.
    Hardware improvement is no doubt a good option. We can really get speedy transfers with thicker connections. I'm wondering can HTTP be evolved?
  • sarveshgupta
    @Guttu: Why the compression algorithms won't work for media files?
  • sarveshgupta
    @Biggie: Don't you think SPDY has evolved HTTP to next level
    SPDY has tried to remove the drawbacks of HTTP by allowing for multiplexed streams, header compression, server push and server hint.
    The one thing is that they have targeted the application layer to avoid any major structural changes for the implementation of this algorithm
  • Guttu
    @guttu-Udy454 • Nov 14, 2009
    sarveshgupta@Guttu: Why the compression algorithms won't work for media files?
    As far as I know media files are already compressed. The current compression algorithms like zip or gzip don't make any difference. And even if new algorithms are created for better compression they will use very high resources, which in turn will need hardware upgrade.
    @thebigk • Nov 14, 2009
    Well, I guess the fundamental change I'm talking about will come only when we can think of the problem HTTP solves - and then build our ideas upon how that problem can be solved in some other way.
  • Ashraf HZ
    @Ash • Nov 14, 2009
    Biggie, if you wish to restrict the discussion at the application layer, then I think you need to make that clear in the topic title. There is no point of talking about anything else right? ๐Ÿ˜‰
  • sarveshgupta
    @sarveshgupta-txtmu5 • Nov 14, 2009
    GuttuAs far as I know media files are already compressed. The current compression algorithms like zip or gzip don't make any difference. And even if new algorithms are created for better compression they will use very high resources, which in turn will need hardware upgrade.
    How it is that media files are already compressed? I mean to ask what is used to compress them in that initial phase?
    And why can't we apply zip or gzip to media files? Can you please provide more insights into this?
  • Guttu
    @guttu-Udy454 • Nov 18, 2009
    sarveshguptaHow it is that media files are already compressed? I mean to ask what is used to compress them in that initial phase?
    There are codecs like MPEG-1, MPEG-2, MPEG-3, MPEG-4, xvid, divx, h264 which compress the original stream. The original or uncompress stream takes GB's of space.
    Just try to zip or gzip a media file. Check the results for yourself.
