  • About server power consumption..
    sea_j
    Member
    Updated: Oct 26, 2024
    Views: 1.2K
    Hi CE'ns...
    Can anybody tell me how much power consumed by a typical server??
    sea_j
    Hi CE'ns...
    What is a 'typical server' ?
  • sea_j
    MemberAug 29, 2014
    Means a server who is running normally... 😉
    AdministratorAug 29, 2014
    sea_j
    The power rating of the machine would be mentioned on the machine or its manual. There's no general answer.
    Your own desktop computer, configured to run as a web server or database server may consume anywhere between 30 - 140 Watt. Totally depends on what all hardware components are attached to the computer/server.
    sea_j
    Doesn't the power consumption is totally dependent on its configuration ? Without knowing configuration how one can estimate the power consumption ?
    If this helps - the power consumption is also determined by how busy the CPU is. A totally busy CPU on iMac machine makes it consume about 229W!
    A mac pro machine, capable of running very complex application consumes anywhere between ~40W to 230W, depending upon how busy the CPU is.
    And server that's setup with Raspberry Pi can consume just 3.5 W 😀
    Soon (around mid-2015) 64-bit ARM servers will come to market, It will be surprising to see how much less power server can consume & still can perform all task which normal (x86_64) servers are capable to do.
