  • pugazh anand
    @pugazh-anand-GgZB1c • Aug 31, 2013
    check it out friend...we can use s52 instead of c52...am i right?
    @abhishek-fg9tRh • Sep 1, 2013
    All I know is,
    89s52 can be programmed with PC, called as In-system Programmable while for 89c52 you'll need Programmer to program the mc.
    Further hardware differences(if there's any) can be obtained from data-sheets.
  • Anand Tamariya
    @anand-tamariya-DnfjEX • Sep 1, 2013
    89C52 is running end-of-life. You should use 98S52 for newer designs.
    @harshad-ukH5ww • Sep 1, 2013
    As said by @#-Link-Snipped-# only difference between both chip is the way you need to program particular chip. Based on different method for programming they have differentiated them with S and C.
  • pugazh anand
    @pugazh-anand-GgZB1c • Sep 1, 2013
    Harshad ItaliyaAs said by @#-Link-Snipped-# only difference between both chip is the way you need to program particular chip. Based on different method for programming they have differentiated them with S and C.
    @#-Link-Snipped-# my quetion is are they have same instrution set? if both same means we can use same code.
    @harshad-ukH5ww • Sep 2, 2013
    pugazh anand@#-Link-Snipped-# my quetion is are they have same instrution set? if both same means we can use same code.
    Yes don't worry about that same code will be there for both MCUs.
