A tricky program 2 to Java Beginners,
ms_cs
@ms-cs-Ab8svl Oct 25, 2024
<a href="https://javacoderblog.blogspot.com/2010/05/tricky-program-1-to-java-beginners.html" target="_blank" rel="nofollow noopener noreferrer">Java Programmer's Blog: A tricky program 2 to Java Beginners,</a>
Question:- You should bring the output by not modifying the main method,The output is "Great Java Programmer".
class NMM //No main method
public static void main(String []args)
System.out.println(“Java”);
Seems tricky? Anybody?
  • Manish Goyal
    @manish-r2Hoep Jun 8, 2010
    May be this code is answer
    static
    System.out.println("Great Java Programmer");
    System.exit(0);
    System.out.println("Java");
    }[IMG]file:///C:/Users/Inder/AppData/Local/Temp/moz-screenshot-5.png[/IMG][IMG]file:///C:/Users/Inder/AppData/Local/Temp/moz-screenshot-6.png[/IMG]
  • ms_cs
    @ms-cs-Ab8svl Jun 8, 2010
    goyal420May be this code is answer
    static
    System.exit(0);
    Nice, the main method must run buddy
  • mohan_185
    @mohan-185-7XDmOn Jun 13, 2010
    I am new to java programming . may be this solution may not be optimal
    class NMM
    System.out.println("java");
    static
    System.out.println("great");
    NMM.main(null);
    System.out.println("programmer");
    System.exit(0);
  • sookie
    @sookie-T06sFW Jun 15, 2010
    @Mohan Good job done
    @ms_cs Are you sure output should be "Great Java Programmer" [in one single line] and not in multiple lines like
    "Great
    Java Programmer"
    or
    "Great
    Java
    Programmer"
  • mohan_185
    @mohan-185-7XDmOn Jun 15, 2010
    @sookie thanks buddy
  • ms_cs
    @ms-cs-Ab8svl Jun 15, 2010
    @mohan_185 : Nice buddy..
    @sookie : yes output should be in one line..
  • mohan_185
    @ms_cs
    output cant be in online because
    After printing java it will go to the next line then only it will print programmer
  • ms_cs
    cool Mohan, there is a trick,or may be a hack 😉,
  • sookie
    @sookie-T06sFW Jun 16, 2010
    [Edit: Removed..Sorry for spamming]
    @ms_cs Well I am giving up. Today realised "I am not even a Java beginner..so sad" 😔 Send me the answer through PM if can't post it here. 😀
  • abhinaykumar
    @abhinaykumar-DQL43M Jun 19, 2010
    public class NMM
    static
    System.out.print("Great ");
    NMM.main(null);
    System.out.print("Programmer ");
    System.exit(0);
    System.out.print("Java ");
    the output is "Great Java Programmer" in single line
    the logic is nothing but using println prints the message in new line if u use only print in sop statement u can get it in single line buddy....
    we cannot print the output in single line coz in the main method u used the println statement for java so its impossible to get the desired output without changing main method.....
  • mathew720
    @mathew720-hOGOMz Jun 19, 2010
    dude i would love to learn Java how , in much time could i learn it , which site would you opt , funny part is i am not even an engineer
    , i have few basics of c++ long back in high school ,its interesting i guess answer i am waiting for an answer too
  • abhinaykumar
    @abhinaykumar-DQL43M Jun 20, 2010
    is there really a trick to print the way with out changin the main method if yes please send me the answer...
  • sookie
    @sookie-T06sFW Jun 21, 2010
    abhinaykumaris there really a trick to print the way with out changin the main method if yes please send me the answer...
    As per me, following program works without changing the main method but I am still not sure it is the answer. But still feeling good after trying atleast something of my own 😁
    import java.io.OutputStream;
    import java.io.PrintStream;
     * @author sookie
    public class Print_GreatJavaProgrammer {
    static
     PrintStream printStreamOriginal=System.out;
     /* Setting the out member of the System class in such a way that it prints nothing*/
     System.setOut(new PrintStream(new OutputStream(){
    			public void write(int b) {
        /* Calling the main method */
       Print_GreatJavaProgrammer.main(null);
       /* Re-setting it so that it prints in actual manner */
       System.setOut(printStreamOriginal);
       System.out.println("Geat Java Programmer");
       System.exit(0);
    Feel free to ask if have any questions regarding it. 😀
    * Still waiting for the actual answer :-| *
  • abhinaykumar
    @abhinaykumar-DQL43M Jun 21, 2010
    hai Sookie can u xplain the statements u used in the static method........
  • ms_cs
    @ms-cs-Ab8svl Jun 21, 2010
    Sookie:- nicely you have done.
    Let me post mine's solution
    import java.io.*;
    public class NMM
    static
    final PrintStream out = System.out;
    PrintStream newOut = new PrintStream(out)
    public void println(String str1)
    print("Great ");
    print(str1);
    super.println("Programmer");
    System.setOut(newOut);
    public static void main(String [ ]argums)
    System.out.println("Java ");
  • Manish Goyal
    @manish-r2Hoep Jun 21, 2010
    @ms_cs Can you please explain this program?
  • ms_cs
    goyal420@ms_cs Can you please explain this program?
    @goyal: I just have written code for overriding the method println(String) which will be used in the main mehtod,,that;s it
  • sookie
    @sookie-T06sFW Jun 22, 2010
    abhinaykumarhai Sookie can u xplain the statements u used in the static method........
    Sure !
    In the above statement, I am making System.out to behave in such a manner that it prints/writes nothing as output in console. It is simply overriding the write() method of OutputStream abstract class. The concept that is used above is called as "Anonymous inner classes". Alternatively you could do is , create a class that extends "OutputStream" class and then overrides its "write" method -just like I did in above statement and then instantiate that implementing class and pass as an argument to "PrintStream" class .
    Well, this was syntax related. Now what exactly that statement does is -
    If you look at System.out.println then System.out is a PrintStream type of class which calls println() method of PrintStream to write anything on console and println() calls "write" method internally . If you look at the API carefully then you will find that write() method is being overriden from FilterOutputStream class which ultimately extends OutputStream class. *sighs* Hope you understood the concept [As per me it was not at all a problem for JAVA BEGINNER until the beginner knows the ready made answer. 😀 ]
    Now coming to the next line
    Now this triggers the main() method and tries to print "Java" from the main() method but because we have already set the write() method as below
    So, it will not print "Java" in the console.
    Now coming to next line
    System.setOut(printStreamOriginal); //where PrintStream printStreamOriginal=System.out;
    Now using above statement , I am again setting the System.out value to the one default provided by Java folks. System.setOut(System.out). It will revert back the System.out to original PrintStream write() method. No overriding, nothing. Only default values.
    Now coming to last line
    The above statement of static block works as normal Java program because we have already re-set the System.out to default print() method.
    Finally System.exit(0) to exit from this program and thread hopefully *just kidding* 😀
    Hope you got the concept and if still any questions, feel free to ask. 😀 I think solution by ms_cs is quite easy to understand but will work only for few cases.
  • abhinaykumar
    @abhinaykumar-DQL43M Jun 22, 2010
    thanks sookie
  • abhinaykumar
    import java.util.Scanner;
    public class Manager
        public static void main(String[] args)
            String[] units={ " ","one","two","three","four","five","six","seven","eight","nine" };
            String[] teens={ " ","ten","eleven","twele","thirteen","fourteen","fifteen","sixteen","seventeen","eighteen","nineteen"};
            String[] tens={ " ", "twenty", "thirty", "fourty", "fifty", "sixty", "seventy", "eighty", "ninety", "hundred" };
            Scanner nte=new Scanner(System.in);
            System.out.println("Enter any Value from One to Hundred");
            try
            int num=Integer.parseInt(nte.next());
            if(num<10)
                int k=num % 10;
                System.out.println(units[k]);
            else
                if(num<19)
                    int m,n;
                    m=num/10;
                    n=num%10;
                    int l=n+m;
                    System.out.println(teens[l]);
                else
                    if(num>19)
                        int a,b;
                        a= num/10;
                        b= num % 10;
                        System.out.println(tens[a-1]+units);
                    else
            catch(NumberFormatException ex)
                        ex.printStackTrace();
    hai guys can anyone tellme how to reduce lines in this program
  • sookie
    Try the below one - if your all cases still working or not
    [B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public
    [/COLOR][/SIZE][/COLOR][/SIZE][/B][LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]class[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] Manager {[/SIZE]
    [LEFT][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]public[/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]static[/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]void[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] main(String[] args) {[/SIZE]
    [SIZE=2]String[] units = { [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]" "[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"one"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"two"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"three"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"four"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"five"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"six"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2],[/SIZE]
    [SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"seven"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"eight"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"nine"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] };[/SIZE]
    [SIZE=2]String[] teens = { [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]" "[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"ten"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"eleven"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"twele"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"thirteen"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2],[/SIZE]
    [SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"fourteen"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"fi fteen"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"sixteen"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"seventeen"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"eighteen"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2],[/SIZE]
    [SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"nineteen"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] };[/SIZE]
    [SIZE=2]String[] tens = { [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]" "[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"twenty"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"thirty"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"fourty"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"fifty"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"sixty"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2],[/SIZE]
    [SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"seventy"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"eighty"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"ninety"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2], [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"hundred"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] };[/SIZE]
    [SIZE=2]Scanner nte = [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]new[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] Scanner(System.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]in[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2]);[/SIZE]
    [SIZE=2]System.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]out[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2].println([/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"Enter any Value from One to Hundred"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]);[/SIZE]
    [B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]try[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] {[/SIZE]
    [B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]int[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] num = Integer.[I]parseInt[/I](nte.next());[/SIZE]
    [SIZE=2][/SIZE]
    [B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]if[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] (num>1 && num < 10) {[/SIZE]
    [SIZE=2]System.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]out[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2].println(units[num%10]);[/SIZE]
    [SIZE=2]} [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]else[/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]if[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] (num>1 && num < 19) {[/SIZE]
    [SIZE=2]System.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]out[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2].println(teens[(num/10)+(num%10)]);[/SIZE]
    [SIZE=2]} [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]else[/COLOR][/SIZE][/COLOR][/SIZE][/B][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]if[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] (num>1 && num > 19) {[/SIZE]
    [SIZE=2]System.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]out[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2].println(tens[num/10 - 1] + [/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]" "[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]+units[num%10]);[/SIZE]
    [SIZE=2]} [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]else[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] {[/SIZE]
    [SIZE=2]System.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]out[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2].println([/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"Invalid Number"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]);[/SIZE]
    [SIZE=2]}[/SIZE][/LEFT]
    [LEFT][SIZE=2]} [/SIZE][B][SIZE=2][COLOR=#7f0055][SIZE=2][COLOR=#7f0055]catch[/COLOR][/SIZE][/COLOR][/SIZE][/B][SIZE=2] (NumberFormatException ex) {[/SIZE]
    [SIZE=2]System.[/SIZE][I][SIZE=2][COLOR=#0000c0][SIZE=2][COLOR=#0000c0]out[/COLOR][/SIZE][/COLOR][/SIZE][/I][SIZE=2].println([/SIZE][SIZE=2][COLOR=#2a00ff][SIZE=2][COLOR=#2a00ff]"Number Format Exception"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]);[/SIZE]
    [SIZE=2]}[/SIZE]
    [SIZE=2]}[/SIZE]
    I guess you should have kept it in separate thread so that we can try to extend this program problem further. 😀
    [/LEFT]
  • abhinaykumar
    @abhinaykumar-DQL43M Jun 23, 2010
    okay sookie
  • Malhar
    @malhar-aRjUaw Mar 23, 2011
    class Test1
    static{
    System.out.print("Great");
  • TheV
    @thev-iGmS6y Apr 1, 2011
    class Manager{
    public static void main(String[] args){
    String[] units={ "","one","two","three","four","five","six","seven", "eight","nine","ten","eleven","twele","thirteen","fourteen","fi fteen","sixteen","seventeen","eighteen","nineteen","twenty" };
    String[] tens={ " "," ","twenty ", "thirty", "fourty", "fifty", "sixty", "seventy", "eighty", "ninety", "hundred" };
    System.out.println("Enter any Value from one to Hundred");
    try{
    int num=nte.nextInt();
    if(num<=20){
    System.out.println(units[num]);
    else{
    int a= num/10;
    int b= num % 10;
    System.out.println(tens[a]+" "+units[b]);
    catch(Exception ex){
    System.out.println("Invalid Input");
    I work out this way....
  • Hemant Patel
    @hemant-IEDwlg May 3, 2011
    // another logic 😉
    import java.util.*;
    class nmm
    public static void main(String ...k)
    nmm() {
    System.out.println("Great Java Programer");
    System.exit(0);
    static nmm jcore=new nmm();
  • spiky
    @spiky-Wr3sG5 May 11, 2011
    init
    System.out.print(“ Java”);
    show();
    static void show()
    System.out.print(" Programmer");
  • Agam Agarwal
    @agam-agarwal-iszT5f Aug 13, 2011
    the solution is easy
    just stop the main method from executing and print what u want to print
    can be done as follows
    static
    {System.out.println("Great Java Programmer");
    System.exit(0);
  • TheV
    @thev-iGmS6y Aug 14, 2011
    You can do this way tooo...
    class NMM{
    static{
       NMM.main(null);
      System.out.print("Programer");
      System.exit(1);
    public static void main(String []args){
  • Java freak
    @java-freak-daoG6u Sep 10, 2015
    public class helloworld{
    static
    System.out.println("java ");
        static
    System.out.print("Devleoper");
