A Simple Question
Neha
@neha-3vibjn Oct 22, 2024
Some Questions from TCS
Hi everyone
Can anyone answer the simple questions.These are the questions i found in last year TCS question papers.
1.A car is filled with four and half gallons of fuel for a round trip.
Fuel is taken 1/4 more in going then coming. What is the fuel
consumed in coming up?
2.Low temperature at the night in a city is 1/3 more than 1/2 high as
higher temperature in a day. Sum of the low tem. and highest temp.
is 100 degrees. Then what is the low temp?
3. A person, who decided to go to weekened trip should not
exceed 8 hours driving in a day. Average speed of forward journey
is 40 m/h. Due to traffic in sundays, the return journey average speed
is 30 m/h. How far he can select a picnic spot?
a) 120 miles
b) between 120 and 140 miles
c) 160 miles
  • Neha
    @neha-3vibjn Apr 2, 2006
    plz do write the solutions to the above questions.
  • Jerry
    @jerry-5wPKU7 Apr 2, 2006
    I couldn't understand this -
    higher temperature
    Ans#1:
    Let 'x' be the fuel consumed during return journey. Then (5x/4) becomes the quantity of fuel required during the forward journey.
    Therefore, x + (5x/4) = 4.5
    => x = 2 is the quantity of fuel consumed while coming up.
    Ans#3:
    Let 'x' be the time (in hours) for forward journey & 'y' be the time (in hours) for the return journey.
    => x+y =8
    If (a) were right, then total distance travelled = 120 x 2 = 240 miles.
    that means 40x + 30y = 240
    Solving for x & y results in x = 0 which is invalid.
    Similarly try for (c). Which results into y = 0 hours.
    Therefore the correct answer is option (b).
    -Jerry.
    p.s. post this question in Quantitative section.
  • Neha
    Answers
    well Jerry, even i got my answer as 2 gallons for the first but the answer to the first question is 20 gallons.
    i couldn't understand second question and answer to the third one is 120miles.
  • rick
    @rick-JybHX8 Apr 2, 2006
    How can it be 20 gallons? 😒
    The car has only 4.5 gallons.
    I couldn't get the answer to question 3. It has to be between 120 & 140 miles.
    How did you get 120?
    rick
  • Neha
    yea u are rite rick the answer had to be 2gallons and the answer to third question should be (b) only.What about question 2 can anyone explain it??
  • sttepz
    @sttepz-25ztSH Apr 3, 2006
    its sooooo simple
    Ans. wel d lower temp. is 40 n d higher's 60.
    REASON : 40 is 1/3 more than 30 which is half of higher temp(60).
    @thebigk Apr 4, 2006
    my way
    I'll tell you how I did it. If you can do it that way, TCS won't be a problem 😀
    Divide 4.5 into 2 & 2.5. Now 0.5 is 25% of 2 . That should give you the answer.
    Sttepz did it the right way.
    If I had only 20 seconds to solve this; I'd divide 8 into 4 + 4. 40x4 + 30x4 = 160+120 = 280. Which is twice of the higher limit in option (b). I can be 90% sure that answer is (b).
    Well, there can be better ways. That was my approach of guessing the answer in shortest time. [​IMG] Accuracy rate is around 80%.
    -The Big K-
  • Neha
    @neha-3vibjn Apr 8, 2006
    Thanx
    Thanx Everybody who took out the precious time for this thread.
  • Neha
    More!!
    1.a sales person multiplied a number and get the answer is 3
    instead of that number divided by 3.what is the answer he actually
    has to get.
    2.a ship started from a port and moving with I mph and another ship
    started from L and moving with H mph.at which place these two ships
    meet.
    3.a building with height D ft shadow upto G.A neighbour building
    with what height shadow C ft is
  • crook
    @crook-0PFkJv Apr 8, 2006
    simple
    has to get.
    😒 Please rewrite the question or give me the options.
    meet.
    Assumption: The ships are moving towards each other 😀
    Let' the ships meet after 't' hours. So,
    t = { L / (I+H) } hrs.
    Therefore, the ships meet at I x t miles from the port. Easy!
    The ratio is D:G . Assuming similar triangles (draw the figure yourself), the height with shadow C ft. should be DxC / G .
    Crook
  • Jerry
    @jerry-5wPKU7 Apr 18, 2006
    good work crook. Neha please confirm the answers.
  • Anil Jain
    @CrazyBoy Apr 28, 2006
    Jerrygood work crook. Neha please confirm the answers.
    still waiting for confirmation of answers......
    --Crazy
  • Neha
    @neha-3vibjn May 8, 2006
    some more....
    These are some of the questions i found in IBM papers...Answers have been marked...Try them Out!!!
    1.From height of 8 mts on ball fell down and each time it bounces half the
    distnace back. so what will be the distance travelled ??
    a.24---->Ans
    b.26
    c.28
    d.none of above answers
    2.If a person sells a product for rs141/- he suffers a loss of 6%.if he has to have a profit of 10%, at what price should he sell it?
    a.200rs
    b.175rs
    c.210rs
    d.165rs---->Ans
    3.which of the following is the sum of 3 consecutive prime nos?
    a.49
    b.59
    c.both a and b---->Ans
    d.100
    4.If 3 houses are to be painted,mr A can paint a house in 6 days mr B can do the same in 8 days...& mr.C in 12 days.if mr A does the work for 8 days & leaves for vacation, & mr B continues the work for the next 6 days, for how many days should mr.C work?
    a.11 days
    b.13 days
    c.17 days---->Ans
    d.None of the Given answers
    5.4 thieves rob a bakery of the breadone after the other.each thief takes half of what is present ,& half a bread...if at the end 3 bread remains,what is the no of bread that
    was present initiallly?
    a.63
    b.65
    c.67
    d.None of the given answers---->Ans
  • Neha
    can anybody give the solutions to 1st,3rd and 4th??
    I got the answer to the 5th one as 80.
    @thebigk May 8, 2006
    solved
    Hi Neha,
    Here we go -
    Well, the series which comes to my mind is -
    8 (initial) + 2 x 4 + 2 x 2 + 2 x 1 + ...... (infinite)
    Which equals : 8 + 2 ( 4+2+1+..... )
    = 8 + 2 [ 4 / ( 1-0.5 ) ] (Infinite Series Sum)
    = 8 + 2 [ 4 x 2 ]
    = 24
    Option 'a'
    a.49
    b.59
    d.100
    49 = 13+17+19
    59 = 17+19+23
    Option 'c'
    To complete the work,
    A must work for 18 Days
    B for 24 Days
    C for 36 Days
    Suppose that total work is of 72 units, then -
    A does 4 units/day
    B does 3 units/day
    C does 2 unites/day
    Now, for the first 8 days, A does 8 x 4 = 32 units
    and for next 6 days, B does 6 x 3 = 18 units.
    Therefore, total work completed by A & B is 32+18 = 50 units.
    Remaining work, which is 72-50 = 22 units has to be completed by C. So with 2 units per day, he will complete the work in 22/2 = 11 Days.
    Option 'a'.
    Please verify.
    -The Big K-
  • Neha
    Thanx!!...well how did u take the total work to be 72units in 4th question??
    Guess?
    18, 24 & 36
    and ...
    72 😀
    umm... Guess? 😉
    -The Big K-
  • rick
    @rick-JybHX8 May 8, 2006
    nehacan anybody give the solutions to 1st,3rd and 4th??
    80? How?
    hey that was a great job, GOOD ADMIN [​IMG]
  • Neha
    i got the answer to 5th one as 89
    solution:
    let the breads initially present to be x.
    then,
    (x/2+1/2) + [1/2(x/2+1/2)]+1/2 + [1/2{1/2(x/2+1/2)+1/2}]+1/2 +
    1/2[1/2{1/2{x/2+1/2)+1/2}+1/2] + 3 = x
    Solving the equation,
    x = 89.
    wat is the sum of infinite series???
    The Sum of an Infinite Geometric Series If -1 < r < 1 (or [​IMG]), then the sum of the infinite geometric series
    [​IMG]
    in which [​IMG] is the first term and r is the common ratio is given by
    [​IMG].
    -The Big K-
  • Ronan Keating
    @ronan-keating-K4QDKn Apr 26, 2011
    the 5 th one is 64..let there be X bread..the 1st one takes 1/2 bread and X/2 bread...so REMAINING bread is (X - 1/2 - X/2) =( X/2 - 1/2)
    2nd one ....................remaining bread - 1/2(remaining bread)-1/2 (X/2 - 1/2) - 1/2 - (X/4 - 1/4) =(X/4 - 3/4)
    3rd one ............................................................................... (X/4 - 3/4) - 1/2 - (X/8 - 3/8) =(X/8 - 7/8)
    4th one ................................................................................ (X/8 - 7/8) -1/2 - (X/16 - 7/16) =(X/16 - 15/16)
    SEE there is a sequence if there is N number of thief AND that is ( X / 2^N ) - ( (2^ N) -1) / ( 2^N)...............
    So if you solve the 4th EQUATION (X/16 - 15 /16) = 3 ....You will see 64 is the ans..which is very close to the options..bt none of them................
