A sequence question
chuackl
@chuackl-nMVZ8P โ€ข Oct 23, 2024
observe the sequence below
1,2,3,5,8,13,.....
starting from the 3rd term, the number is the sum of the previous 2 term. Find the remainder when the 2008th term is divided by 8.
I calculated the remainder should be 5 correct? Just wanted to verify with you people because i dun have the answer for this question. Feel free to post ur solution so that i can see is it same as mine?
  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M • Nov 25, 2009
    Yes the answer is correct!!
    I have found the number using Java Program.
    This is the number I think its correct.
    "321132499826815828452384720320970862074060782643692138282072697388735283721646581360160762436827841025561894548480898890020542623496809423664669723066980931624908775724739402394881483009611433054415348267177640331222672835631629564907858584307850508476151574891670117047739206178124320617556197699087423367414181105249300715385128794295920765953173508643733461099002087678765648760921612656571558458025510084617009128909"
    The remainder is 5!!
    Is there any easy procedure to find it.. I just went with programatical approach..
  • yadavundertaker mohit
    @yadavundertaker-0p3HBs • Nov 26, 2009
    i must say you are genius ES...
    i am trying this question from mathematics point of view but forget that the number will be too large to handle....
  • chuackl
    @chuackl-nMVZ8P • Nov 26, 2009
    thank you to you people for providing the answer to compare๐Ÿ˜.
    My solution appear to be different.
    For the sequence 1,2,3,5,8,.....
    when divided by 8, for the 1st term remainder will be 1 since 1 cannot be divided by 8 and 2nd term will be 2,3rd term will be 3,4th term will be 5 and 5th term will be 0. I just observed the pattern actually there is not needed to add the sum for the next term than divide that number by 8. Starting from the 6th term, the remainder will be 5 because the remainder at 4th term is 5 and 5th term is 0 so what needed to do at here is to add up the previous 2 term's remainder. After that, take the sum of the remainder minus by 8, if the sum is smaller than 8 than the sum is the remainder else the remainder is the sum of the remainder of previous 2 term minus by 8.
    So here is the remainder starting from 1st term.
    1,2,3,5,0,5,5,2,7,1,0,1,1,2,3,5,0,5,5,2,7,1,0,1,1,..........
    notice that except the first 3 term, the remainder is keep on repeating starting from 4th term until 15 term, it repeat after 12 term
    so at here i create a formula
    3+n(12)=2008
    n=167.083
    however i only take integer value of 167
    3+167x12=2007
    that mean starting from 3rd term after 167 times the set of the 12 number, the remainder will be 3, and further up 1 more term will be 5.
    @saandeep-sreerambatla-hWHU1M • Nov 26, 2009
    Excellent solution friend ๐Ÿ˜€
