A project for machine elements
cmstaromana
@cmstaromana-n2EJIv โ€ข Oct 8, 2024
I (badly) need creative ideas for my project in machine elements (kinematics).
We are required to build a simple machine or combination of mechanisms.
Our project must have at least two of the following:
Quick-return mechanism
Four-Bar Linkage
(Crank-Rocker, Drag Link, Parallel, Non Parallel Four Bar)
Toggle mechanism
Slider-Crank mechanism
Oldham Coupling mechanism
Scotch Yoke mechanism
Straight Line mechanism
Intermittent-Motion mechanism
Universal Joint mechanism
Parallel Mechanism mechanism
Elliptic Trammel mechanism
Flexible Drives
Do you have any suggestions?
Or kindly help me with whatever you can. I will be very grateful to you. :smile:
It should be simple and easy to make ๐Ÿ˜
  • Capt Spark
    @capt-spark-xvppcH • Aug 30, 2010
    why dont you try to make a horizontal shaping machine model? If I remember correctly, it will use slider crank + quick return mechanism (assuming that power comes from a rotating motor and the shaping tool head return must be faster than the cutting shot) atleast, if not more. And for the mechanism details plz remember that east or west, Google is the best ๐Ÿ˜‰
