A COMBINATION OF SHUNT HYBRID POWER FILTER AND THYRISTOR-CONTROLLED REACTOR FOR POWER QUALITY
@shyamakant-kumar-yBNMBL
1.5K
Project Abstract / Summary : This paper proposes a combined system of a thyristor-controlled reactor (TCR) and a shunt hybrid power filter (SHPF) for harmonic and reactive power compensation. The SHPF is the combination of a small-rating active power filter (APF) and a fifth-harmonic-tuned LC passive filter. The tuned passive filter and the TCR form a shunt passive filter (SPF) to compensate reactive power. The small-rating APF is used to improve the filtering characteristics of SPF and to suppress the possibility of resonance between the SPF and line inductances. A proportional–integral controller was used, and a triggering alpha was extracted using a lookup table to control the TCR. A nonlinear control of APF was developed for current tracking and voltage regulation. The latter is based on a decoupled control strategy, which considers that the controlled system may be divided into an inner fast loop and an outer slow one. Thus, an exact linearization control was applied to the inner loop, and a nonlinear feedback control law was used for the outer voltage loop. Integral compensators were added in both current and voltage loops in order to eliminate the steady-state errors due to system parameter uncertainty.
Why did you choose to work on this project topic : In this paper, a new combination of a shunt hybrid power filter (SHPF) and a TCR (SHPF-TCR compensator) is proposed to suppress current harmonics and compensate the reactive power generated from the load. The hybrid filter consists of a series connection of a small-rated active filter and a fifth-tuned LC passive filter. In the proposed topology, the major part of the compensation is supported by the passive filter and the TCR while the APF is meant to improve the filtering characteristics and damps the resonance, which can occur between the passive filter, the TCR, and the source impedance. The shunt APF when used alone suffers from the high kilovoltampere rating of the inverter, which requires a lot of energy stored at high dc-link voltage. On the other hand, the standard hybrid power filter is unable to compensate the reactive power because of the behavior of the passive filter. Hence, the proposed combination of SHPF and TCR compensates for unwanted reactive power and harmonic currents. In addition, it reduces significantly the voltampere rating of the APF part. The control method of the combined compensator is presented. A control technique is proposed to improve the dynamic response and decrease the steady-state error of the TCR. It consists of a PI controller and a lookup table to extract the required firing angle to compensate a reactive power consumed by the load. A nonlinear control of SHPF is developed for current tracking and voltage regulation purposes. It is based on a decoupled control strategy, which considers that the controlled system may be divided into an inner fast loop and an outer slow one. The currents injected by the SHPF are controlled in the synchronous orthogonal dq frame using a decoupled feedback linearization control method. The dc bus voltage is regulated using an output feedback linearization control.
Institute/College Name: sree sastha institute of engineering and technology
City: chennai
State: tamilnadu
City: chennai
State: tamilnadu
