a boat in a river problem..........
lovejeet
lovejeet
@lovejeet-etHdkD Oct 17, 2024
i came across a nice tricky question:-
let there are two rivers............ river A and river B. water is flowing in river A with some speed, and stagnated ( not flowing) in river B. there are two boats, one in each river..... they have to travel a same distance, say x, and then return back at the starting point......
so which boat will return first????
note:- speed of water is less than the speed of boat, and both boats travel with same speed...........
  • eternalthinker
    eternalthinker
    @eternalthinker-Kvsi5Y Jan 25, 2011
    Isn't it the boat in the flowing river that will travel to and fro in the shortest time?
  • Reya
    Reya
    @reya-SMihdC Jan 25, 2011
    I guess the boat in River B.Which is correct?
  • lovejeet
    lovejeet
    @lovejeet-etHdkD Jan 25, 2011
    any explanation?????
    and ya, boat is not traveling from one bank to another..........its traveling in the direction of water and then returning back..........
    the diagram would make it clear.............
    starting point <-----------------x------------------>half way, as boat will return back to starting pt....
  • rajeshchahar
    rajeshchahar
    @rajeshchahar-m1KsOz Jan 25, 2011
    boat in river A will come first
  • eternalthinker
    eternalthinker
    lovejeet
    I just substituted dummy values for both. And the boat A was a wee bit faster 😉
  • lovejeet
    lovejeet
    yup............... the answer is B. but any mathematical explanation?????
  • eternalthinker
    eternalthinker
    @eternalthinker-Kvsi5Y Jan 28, 2011
    The time taken by boats A and B will be in the ratio:
    1/v(v^2 - a^2) : 1
    Clearly, boat A takes lesser time.
    Hence the result 😉
  • shreyasm89
    shreyasm89
    @shreyasm89-jGobVm Jan 28, 2011
    @eternalthinker- I'm not able to understand your formula. Could you plz explain
  • freak16
    freak16
    @freak16-XgiLj6 Jan 28, 2011
    suppose x=3m,speed of boat=5m/s and speed of river=2m/s!t1=time taken by boat in river A,t2=time taken by boat in river B!
    then,t1=3/(5+2) + 3/(5-2)
    = 3/7 + 3/3
    = 1.42 sec.
    t2=(2*3)/5
    = 1.2 sec
    so t1>t2..means boat in river b will reach faster.....please someone explain...how the answer is A then??
    am i doing the solution wrong??
  • lovejeet
    lovejeet
    @lovejeet-etHdkD Jan 29, 2011
    sorry for the mistake.................... freak you are correct............correct answer is B. i just wrote option A mistakenly......
    the mathematical explanation is:-
    let speed of the boat be s, speed of water be w, and distance be x
    we have the relation, time= dis/speed....
    now, case A:-
    time, Ta = x/(s+w) + x/ (s-w)
    = 2xs/ (s*s - w*w)
    case B:-
    time, Tb = x/s+ x/s = 2x/s
    now, tb/ ta= (s*s- w*w)/ (s*s) = 1- (w*w)/(s*s)
    clearly, ta is greater than tb...............
    therefore correct answer is B.
  • Reya
    Reya
    @reya-SMihdC Jan 29, 2011
    Tb=x/s+x/s=2xs??
    how come??Tb=2x/s 😀
    Ta=2xs/(s*s-w*w)??How come?
    Isn't Ta=xs-xw+s^2+sw/s^2-w^2 if the value of Ta=x/(s+w)+s/(s-w) ?
    Do tb and Tb are same??
    If yes then how did you calculate tb/ta=1-(w*w)/(s*s)??
    Pls explain me!
  • freak16
    freak16
    @freak16-XgiLj6 Jan 29, 2011
    See Praveena
    Tb=(2*x*s)/s^2-w^2
    Ta-(2*x)/s
    now divide Ta By Tb
    you must get it
  • Reya
    Reya
    I know the answer!
    @Freak:Just look at the value of Tb and Ta posted by lovejeet!
    Isn't it wrong??
  • lovejeet
    lovejeet
    thanks a lot praveena for replying and pointing out the mistake.........
    i m sorry for the mistakes...................... sorry for my casual writing..........
    the value of Ta,will be:-
    Ta= x/(s+w) + x/ (s-w)
    = [ x(s-w) +x (s+w) ]/ (s^2-w^2)
    = 2xs/ (s^2- w^2)
  • ISHAN TOPRE
    ISHAN TOPRE
    @ishan-nohePN Jan 29, 2011
    Its damn simple
    Both the boats assuming that they with pedal same amount of energy, will return at same time.
    1)Boat in river A:It will be easy in downstream but will face opposition in upstream.
    Let Speed of boat be 'x' and that of river water be 'y'.
    downstream velocity=x+y; upstream velocity=x-y;
    Hency average velocity=(x+y+x-y)/2=2x/2= x
    2)Boat in river B:It will have same velocity as 'x' any way😁
