  • A bike with Infinite Gears: Novara Gotham
    pradeep74m
    pradeep74m
    @pradeep74m-8WZl5m
    Updated: Jun 19, 2012
    Views: 1.2K
    A NuVinci bike effectively has an infinite number of gears. You can adjust it smoothly, without worrying about clicking into gears, to provide the precise right amount of resistance. You can start at a very low gear to pedal easily and then smoothly ramp up to a higher gear as you gain speed. And since everything is internal, repairs are rarely necessary. It's a revolution, really--one of the most fundamental changes to the bicycle in decades.
    [​IMG]
    The basic concept is pretty simple. As in other internally geared systems, a traditional front chain ring and cog are used to provide power, but the entire transmission resides within the rear hub, rather than the changing ratio between a front chain ring and a set of rear cogs determining the relationship between power input and output.
    Full details:#-Link-Snipped-#
    Its looks cool, hope it will resolve the problem of jamming of gear which changing.
    AdministratorJun 19, 2012
    Pardon my limited Mechanical Engineering knowledge; but why'd they call it an 'infinite gears' system? I've seen the video on the link but it's still not clear. What I'm more interested in knowing is does the system make me put lesser efforts uphill?
  • pradeep74m
    MemberJun 19, 2012
    Ya the bike clearly makes uphill an easier task. The bike distinguishes the amount of effort required to perform the task which is different from the traditional gearing system where you have to decide the right number of gear for the uphills and flat surface.
  • nibhani
    MemberJun 21, 2012
    i m not g
    pradeep74m
    [​IMG]
    i m not getting the concept of this byke,,can u explain me clearly?
  • nibhani
    MemberJun 21, 2012
    how
    pradeep74m
    Ya the bike clearly makes uphill an easier task. The bike distinguishes the amount of effort required to perform the task which is different from the traditional gearing system where you have to decide the right number of gear for the uphills and flat surface.[/quote
    pradeep74m
    .i m not getting that how can u say it as infinite gear vehicle...?
  • pradeep74m
    MemberJun 21, 2012
    What they are stating is effectively infinite number of gears. You shouldn't take the literal meaning as it is. If you study the full details clearly the amount of resistance you can give is not limited by the number of gear as in conventional system. Here you can choose the amount of resistance you need without limitation of numbered gear system.
  • gohm
    MemberJun 22, 2012
    So it seems to work on a similar principal as a cvt system found on scooters and formula 500 race cars. Is that right?
  • pradeep74m
    MemberJun 22, 2012
    Ya it functions similar to cvt.
  • CE Designer
    MemberJun 22, 2012
    The_Big_K
    I think popsci.com may have over-exhaggerated the description. What this sytem offers is, like the regular cvt, is an infinite number of gear ratios within its range. That is the range it is designed for. Within that range you can access different gear ratios in an incrimental manner rather than discrete pre-determined gear ratios. This means you can gradually increase torque and speed. This answers your last question K, yes it should make uphill traverse easier. I think its an amazing design of CVT. What of the cost of this? #-Link-Snipped-# If i wanted to buy the unit itself how much will it cost me?
    AdministratorJun 22, 2012
    That makes more sense. 'Infinite Gear' looks to be marketing term they're using. Infinite number of gear ratio is what they're offering.
  • pradeep74m
    MemberJun 23, 2012
    CE Designer
    The gear unit alone costs around 350$.
  • CE Designer
    MemberJun 25, 2012
    pradeep74m
    Waw and thats US$ right?
  • pradeep74m
    MemberJun 25, 2012
    CE Designer
    Yes, its US$.
