4 wire kelvin test
chuackl
@chuackl-nMVZ8P • Oct 21, 2024
when measuring very low resistance(miliohm), it is necessary to perform 4 wire test in order to get an accurate reading. However, can opamp(comparator) provide a better accuracy when come to resitance comparison?(ie does opamp able to differentiate a 11miliohm and 10miliohm resistor? provided using the same amount of current supply to the resistor). since the open loop gain of an opamp can reach 1x10^6 which suggest it capable to amplify a very small value to a significant value.
Theoretically, it should working but anyone know does it applicable even in practical?
  • Jeffrey Arulraj
    @jeffrey-xA7lUP • Sep 30, 2013
    Theoretically all is well but not practically
    Whenever you have an Opamp the paramters required to fix it to work with 100% efficiency are really tedious to meet
    No device is 100% efficient But you can approximately differentiate the values of resistors But finding exact value with 741 is not possible in any practical scenario
