  • Can someone please help me with this logic circuit problem?
    Aruwin
    Aruwin
    @aruwin-WQ7eeu
    Updated: Oct 25, 2024
    I need step by step explanation and solution to this question please, so I can answer others.
    In the set of inputs a,b,c,
    in the case there are 2 or more numbers of '1' in the set, it is designated 1, or else, it is designated 0.
    Consider that logical function f above.
    1. Draw the truth table for f.
    2. Find the simplest product-of-sum expression for f.
  • Jeffrey Arulraj
    MemberOct 29, 2012
    Here this should help
    A B C F max terms
    0 0 0 0 A+B+C
    0 0 1 0 A+B+C'
    0 1 0 0 A+B'+C
    0 1 1 1
    1 0 0 0 A'+B+C
    1 0 1 1
    1 1 0 1
    1 1 1 1
    So the final expression for f is
    f=(A+B+C).(A+B+C').(A+B'+C).(A'+B+C)
    Do simplify it further if you want to friend
  • Aruwin
    MemberOct 29, 2012
    jeffrey samuel
    A B C F max terms
    0 0 0 0 A+B+C
    0 0 1 0 A+B+C'
    0 1 0 0 A+B'+C
    0 1 1 1
    1 0 0 0 A'+B+C
    1 0 1 1
    1 1 0 1
    1 1 1 1
    How to further simplify this function?
    f= a'bc+ab'c+abc'+abc
    = c(a'b + ab') + ab (c' + c)
    =c(a'b + ab') + ab
    I only got it up to here. How to simplify it into the most simple expression?
  • Vishal Sharma
    MemberOct 29, 2012
    Aruwin
    =c(a'b + ab') + ab
    I don't think you can simplify it further..
    the next step will be writing XOR expression instead of a'b+ab'
    i.e. c (a XOR b) + ab
    (You can replace the XOR by this sign too)
    xor-symbol.thumbnail
  • Jeffrey Arulraj
    MemberOct 30, 2012
    I think this is the most simplified form the Answer can ever get
