Solid lubricants and their applications
We all know what is lubricants & why is it used used for. Here, Graphite & Molybdenum disulphide are solid lubricants. State where are there lubricants used & how they differ from other lubricant i.e, from semi-solid - liquid lubricants.
Kaustubh KatdareNote: Please provide appropriate titles to your discussions. I've changed the title from 'Lubricants' to something that makes more sense. 😀 A good title helps attracting more replies and readers quickly know what the discussion is about.
Herin HRYeah sir
I'll correct it
Shashank MogheThe OP looks like he is asking a homework question. This should be discouraged.
Viswanathan ChockalingamSolid lubricant is used to reduce Friction in places where the temperature is too high, that a liquid lubricant can loose its properties.
Generally used solid lubricants/Dry lubricants are graphite,Molybdenum disulfide, Hexagonal Boron nitride, Tungsten disulfide.
They have layered structures, Heat bearing capabilities, shock absorbing capabilities, etc.,
Graphite flakes in Cast Iron acts as a lubricants and so lubricants are not used while machining cast iron.Used in Air Compressor, food industry, railway track joints, open gear, Ball Bearing, machine-shop works, etc.
Molybdenum disulfide and Hexagonal Boron nitride are used in space. -
SIVAKUMARG
---- Graphite flakes usage as lubricant in cast iron machining is indeed a new info for me . Thank youViswanathan CSolid lubricant is used to reduce Friction in places where the temperature is too high, that a liquid lubricant can loose its properties.
Country’s second largest free messaging app Hike recently brought in its biggest ever update for Windows 8.1. The features on the offer includes a sparkling new user interface that makes...
What is the role of an engineer in society & in National Development? How must be a future engineer must be? What's ur point of view?
Why is any number raised to zero power equals one ? 0!
Why does the clock in space moves solwer than the clock in earth?
How does the current, voltage & resistance are related with each other? Which plays a major role?
