The role of zero in the power of a number
Why is any number raised to zero power equals one ? 0!
JoellenthompsonRaising a number to the power of zero is not the same as if the exponent is a number other than zero.However, as usual, zero is different. When used as an exponent, it does not work the same as other numbers.
The rule for zero as an exponent is that any number or variable (except zero itself) raised to the 0 power is equal to 1.
For example:
4^0 = 1
b^0 = 1
478^0 = 1.
If you need more solutions or you need more clarification in the field of exponents with zero that can be provide by online resources. -
shiwa436a^0
=a^(n-n)
=a^n/a^n
=1
Why does the clock in space moves solwer than the clock in earth?
How does the current, voltage & resistance are related with each other? Which plays a major role?
The current online banking system works on the basis of two step authentication where a combination of your password and an OTP that you receive on your cellphone is used....
Both petrol & diesel are secondary fuels obtained from the primary fuel petroleum crude. But when they come to engines they play different role due to their chemical compositions. But...
Does anybody have any idea on DNS and DNSSEC hierarchy test bed setup and implementation.???
