Is router a software or hardware?
can anyone help me to know what exactly a router is..
i know the functionality of routers,
i just wanna know the structure of router,
and how the structure works....
please help me as soon as possible
Anoop KumarRouter is Traffic inspector of your network who can't bribed 😉.
It piece of hardware which maintain traffic of network flow on basis of some set of rules which can be configured in its own OS (firmware).
General purpose of router is primary and most powerful firewall from outside network and distribution of network into your local network.
PS: Switch is also a network hardware which distributes network without filtering. -
tanvisharma
yes but its still not clear, can you please elaborate it...ianoopRouter is Traffic inspector of your network who can't bribed 😉.
i know that it is a hardware, but it do function like, traffic control n all, where are all these in that device?
are there any chips or any software stuff inside it?
"It piece of hardware which maintain traffic of network flow on basis of some set of rules which can be configured in its own OS (firmware)."
what is its awn os here??? wats a firmware???
waiting for your response... -
Abhishek RawalFirmware means a program which is loaded inside the ROM of the hardware.It controls how the specific hardware in which it is installed will work.
Router,Scanner,Printers,etc almost every electronics devices have Firmware. -
Kaustubh KatdareIt's a hardware that functions because of the software (firmware). Check this thread for difference between firmware and software: Difference between Firmware and Software
Anoop Kumar#-Link-Snipped-#
Firmware controls the hardware, like you see a music player. If you remember old cassettes/cd players physical keys controls volume changing track, seek or stop function but later music players come with control panel to view and touch buttons. These are handled by hardware specific firmware (software).
Exactly the same way routers have firmware to provide you easiness to manage your network.
Generally you can access your router by
https://router https://192.168.1.1
I hope you got cleared out what exactly router is all about. -
rahul69
A simpler analogy is a mobile phone. Now think, is it hardware or software?? It performs different functions based on some set of rules which can be configured in its own OS, right!!! Similar is the case with router, I hope this helps in clearing your doubt a bit😀.tanvisharmayes but its still not clear, can you please elaborate it...
tanvisharmathank you all....
durga chRouter is a filtering and forwarding device required in any network. Filtering here refers to checking the packets and dropping them and forwarding refers to sending across the packet to appropriate out port.
frankly in that sense, router and switch both does filtering and forwarding, but the difference being router acts on L3 headers where as switch acts on L2 headers, also the fabric within the devices vary to facilitate this functionality.
All hardware devices need a software counterpart to run on them. Routers in general are considered software based operators, where as L2 devices are hardware switches- that doesnot mean they don't have OS. Since routers have historically been software based , its on routers that we can implement filter lists, QoS policies and other traffic engineering techniques.
Though , now a combination of these (hardware switching + router functionality) combined together and brought across as L3 device. -
Scorpion007Basically Router is used to rout the data traffic. Basically router is used to Connect Two or more different networks of IP range.
Most of us(CEans), in that case all are Engineers...
I need your poll on Engineering Education.
Obvious answer is : Well its not good. It should be improved.
Lets discuss...
India seems to be keen on setting up a high-speed bullet train route between Mumbai & Ahmedabad. The technology to setup bullet train will be provided by Japan. The project...
sir , Is that possible to mix any gases or chemicals to the exhaust gas in silencer after combustion in the internal combustion engine that reduce or convert the greenhouse...
Gmail's renovating its user interface starting today in an attempt to let users have full authority over how they wish to organize their mails. The new design shall be rolled...
And today as of posting time it is 6 min and still the resource is not added in the latest resources segment in the main screen Why is it so?...
