Why does a low wattage bulb glow brighter than a high wattage bulb in series connection?
ANU SEKAR
@anu-sekar-0vMhfV โ€ข Oct 27, 2024
If there are two bulbs connected in series to 230v supply, why low watts bulb glow brighter?
  • Jeffrey Arulraj
    @jeffrey-xA7lUP Jun 12, 2013
    Low watt CFL bulb grows brighter than ordinary filament bulb cos they use different principle than that of filament lamps
  • lal
    lal
    @lal-R60Xjx Jun 12, 2013
    Well, let us consider two bulbs in series. A low wattage bulb has higher resistance than the high wattage bulb.
    When connected in series, the same current will be flowing through both bulbs. Let it be I.
    Power output = I X I X R
    R is higher for low wattage bulb. So It will glow brighter.
  • Sindhu Chowdary
    @sindhu-chowdary-tDAv1D Jun 14, 2013
    The higher-wattage lamp has a lower resistance than the lower-wattage lamp. So, when they are connected in series, the larger voltage drop (IR) will appear across the lower-wattage lamp. As power is proportional to the square of the voltage, it is the lower-wattage lamp that will be the brighter.
