  • shameer ariff
    @shameer-5VAwRI • May 10, 2016
    The Arm is a miniature super power processor with very less power consumption. Now a days almost all the electronic system manufacturer are migrating to ARM based processor right from your cellphone. The requirement of the ARM processor is very high in the market so you need to learn arm programming if you want to be in the electronic field...
    @harshad-ukH5ww • May 30, 2016
    vasanth kumar.swhy i need to learn arm programming is this helps me to be an employee
    In very simple answer now a days we need higher features and processing in any application and microcontrollers like 8051 and other 8 bits are only used when the requirement is simple and minimal. Additionally now a days ARM processors are available in the price of other lower range 8bit MCUs so ARM is more in use in industries so if you learn that then it would be helpful to you in future.
