What’s the best furnace design?
Hammer_Time
Hammer_Time
@hammer-time-eMyta7 Oct 26, 2024
I’ve been trying to find the answer to this question for a while and don’t really seem to be getting anywhere. I can’t find any really useful information on this. I visited and heard about many companies who seem to having problems designing a really efficient furnace. Personally I’m trying to improve the design for a furnace that heats up 3 vats in series (I know parallel is better) . But I think we should try and make a list of the things that need to be addressed when considering a furnace design and try and answer as much of the question as possible. I believe this will be very useful for people. So please if you have anything to add to the list or you can help by answering some of the points it would be greatly appreciated.
…What are the ideal gaps between and under vats when using a furnace to cook or boil water to allow enough space for the heat to flow but not too much so that you are not just heating dead space?
Should the floor of the furnace be inclined towards the chimney?
The use of dampers on the chimney had been suggested to me to keep the heat in but will this not restricted the smoke from exiting and clog up the fire?
What is the best material to use?
What is the ideal chimney size and should dampers to used?
P.S is this the right place for thread?
    @thebigk May 24, 2012
    Thread moved to Mechanical engineering section. 😀
