  • What is the minimum value of char type?
    rengaraj
    Member
    Updated: Oct 27, 2024
    Views: 2.8K
    Sir / madam,
    My question is
    What is the minimum value of char type. Select the one correct answer.
    a. 0
    b. -215
    c. -28
    d. -215-1
    Advance Thanks,
    R.Rengaraj
    {Java Certification Quiz}
    {On this forum my 19th Question.}
  • Mahesh Dahale
    MemberDec 4, 2009
    a. 0
    b. -215
    c. -28
    d. -215-1
    char: The char data type is a single 16-bit Unicode character. It has a minimum value of '\u0000' (or 0) and a maximum value of '\uffff' (or 65,535 inclusive).
  • sarveshgupta
    MemberDec 4, 2009
    @Mahesh: char type can also be 8-bit character for C/C++
    In Java we have it to be 16 -bit I suppose
    Although it will have a minimum value of 0 for both the cases as you have told.
    Am I correct?
  • rengaraj
    MemberDec 5, 2009
    Sir,
    Thanks for your reply.
    R.Rengaraj
  • pradeep_agrawal
    MemberDec 9, 2009
    In C a variable of type char can also hold a -ve value and the range is from -128 to 127. So the min. value taht a char variable can have in C is -128.
    If someone want that char variable hold only positive values in C then he/she need to use "unsigned char" instead of "char" while declaring the variable.
    -Pradeep
  • sarveshgupta
    MemberDec 9, 2009
    Mr Rengaraj has to confirm the right answer for the question..May be you are right Pradeep
  • rengaraj
    MemberDec 9, 2009
    Dear Mahesh,
    You quoted 0 to be the answer.
    But it is for unsigned char . not for char.
    mahesh_dahale
    a. 0
    b. -215
    c. -28
    d. -215-1
    R.Rengaraj
  • rengaraj
    MemberDec 9, 2009
    Dear Pradeep,
    You are right, Unsigned Char has a min. value of 0.
    While,
    Char has a min value of -128.
    Excellent discussion.
    Thanks to all of you.
    pradeep_agrawal
    -Pradeep
    R.Rengaraj
