what is error in below code ?
#include <stdio.h>
#include<malloc.h>
struct node
int data ;
struct node *next,*prev;
int main()
    int n ,m,a,count=0,i,j;
    char rot;
    scanf("%d",&n);
    fflush(stdin);
    scanf("%d",&m);
    fflush(stdin);
    printf("\n");
    struct node *head1=NULL,*rear1,*ptr,*temp,*head2=NULL,*rear2;
    if(head1==NULL)
        temp=(struct node*)malloc(sizeof(struct node));
        scanf("%d ",temp->data);
        temp->next=NULL;
        head1=temp;
        ptr=head1;
        head1->prev=NULL;
    for(i=1;i<=n-1;i++)
        ptr->next=temp;
        temp->prev=ptr;
        ptr=temp;
    rear1=ptr;
    temp=NULL;
    ptr=NULL;
    printf("\n");
    if(head2==NULL)
        temp->next=NULL;
        head2=temp;
        ptr=head2;
    for(i=1;i<=n-1;i++)
        ptr->next=temp;
        ptr=temp;
        ptr->next=NULL;
    rear2=ptr;
    ptr=NULL;temp=NULL;
    printf("\n");
    for(i=0;i<m;i++)
    scanf("%c %d",&rot,&a);
    fflush(stdin);
    if(rot=='L')
        ptr=head1;
        for(j=0;j<a;j++)
            temp=ptr->next;
            rear1->next=ptr;
            rear1=ptr;
            head1=temp;
            ptr=head1;
        count++;
        ptr=NULL;
        temp=NULL;
        if(head1->data==head2->data && rear1->data==rear2->data)
            break;
    else if(rot=='R')
        temp=head1;
        ptr=rear1->prev;
        for(j=0;j<a;j++)
            temp->prev=rear1;
            rear1->prev->next=NULL;
            rear1->next=temp;
            head1=rear1;
            temp=head1;
            rear1=ptr;
            ptr=rear1->prev;
        count++;
        temp=NULL;
        ptr=NULL;
        printf("\n");
            break;
    printf("%d",count);
    return 0;
This is a snippet of code which accepts two arrays initial and target and 'm' operations in the form of R X and L X where L X is for left rotation by 1 and R X is for right rotation by 1 ,we have to output the no of operations after which initial and target array both are same , I created queues where head1 and head2 are pointers to front nodes of initial and target arrays , Now the issue is that after I scan the first operation , it stops working ,please tell the point where I am making mistake .
  • aishwarya mk
    aishwarya mk
    @aishwarya-hnVUq3 Jul 12, 2016
    in scanf function u mis the "&" symbol u check once
    in the line scanf("%d",&header1->data);
    because data is integer data type
  • brahmaasthra
    brahmaasthra
    @brahmaasthra-quGsJu Jul 12, 2016
    #include <stdio.h>
    #include<malloc.h>
    struct node
    int data ;
    int main()
    char rot;
    scanf("%d",&n);
    fflush(stdin);
    scanf("%d",&m);
    fflush(stdin);
    printf("\n");
    if(head1==NULL)
    int inp;
    scanf("%d ",&inp);
    temp->data=inp;
    temp->next=NULL;
    head1=temp;
    ptr=head1;
    head1->prev=NULL;
    for(i=1;i<=n-1;i++)
    int inp;
    scanf("%d ",&inp);
    temp->data=inp;
    ptr->next=temp;
    temp->prev=ptr;
    ptr=temp;
    rear1=ptr;
    temp=NULL;
    ptr=NULL;
    printf("\n");
    if(head2==NULL)
    int inp;
    scanf("%d ",&inp);
    temp->data=inp;
    temp->next=NULL;
    head2=temp;
    ptr=head2;
    for(i=1;i<=n-1;i++)
    int inp;
    scanf("%d ",&inp);
    temp->data=inp;
    ptr->next=temp;
    ptr=temp;
    ptr->next=NULL;
    rear2=ptr;
    ptr=NULL;temp=NULL;
    printf("\n");
    for(i=0;i<m;i++)
    fflush(stdin);
    if(rot=='L')
    ptr=head1;
    for(j=0;j<a;j++)
    temp=ptr->next;
    rear1->next=ptr;
    rear1=ptr;
    head1=temp;
    ptr=head1;
    count++;
    ptr=NULL;
    temp=NULL;
    break;
    else if(rot=='R')
    temp=head1;
    ptr=rear1->prev;
    for(j=0;j<a;j++)
    temp->prev=rear1;
    rear1->next=temp;
    head1=rear1;
    temp=head1;
    rear1=ptr;
    ptr=rear1->prev;
    count++;
    temp=NULL;
    ptr=NULL;
    printf("\n");
    break;
    printf("%d",count);
    return 0;
  • brahmaasthra
    brahmaasthra
    copy and run this program and tell. Whether it works well?
  • Vishal Sharma
    Vishal Sharma
    @vishal-pysGmK Jul 15, 2016
    #-Link-Snipped-# No one asked you the entire code
  • aishwarya mk
    aishwarya mk
    @aishwarya-hnVUq3 Aug 4, 2016
    for structure also u should specifies te data qualifiers
