What is electrical Lenght of Antenna ?
aksa
@aksa-fXgUdo Oct 26, 2024
Hello, This is Aksa from Punjab. I am an electrical engineer. I want to know what is the Electrical length of Antenna? Can someone explain with an example?
  • shreya_rulz
    @shreya-rulz-ypF0sg Oct 26, 2009
    electrical length of antenna is the physical length itself but specified using electrical terms.e.g : most antenna lengths are specified to be either 'l/2'or 'l/4' where l is the wavelength of the signal to be propagated.the antenna length depends on the type of signal to be transmitted and the distance the signal covers before it reaches the desired receiver.
    p.s:i wanted to use 'lambda' which is the universal symbol for wavelength but didnt know how to type it..
  • aksa
    @aksa-fXgUdo Oct 26, 2009
    shreya_rulzelectrical length of antenna is the physical length itself but specified using electrical terms.e.g : most antenna lengths are specified to be either 'l/2'or 'l/4' where l is the wavelength of the signal to be propagated.the antenna length depends on the type of signal to be transmitted and the distance the signal covers before it reaches the desired receiver.
    thanks shreya
