Water swirl algorithm
friends,do anyone know about water swirl algorithm?very urgent!
Jeffrey ArulrajPDF
Looks like this article covers swirling hydrodynamic algorithms not sure whether it suits your need -
ABHINANDthanks jeffrey,but it is not the one what am looking for.i need water swirl optimization algorithm for optimizing one of my problem
Ramani AswathYou may get a better response if the problem is stated.
ABHINANDactually the problem is MPPT(maximum power point tracking) of PV CELL.
Ramani AswathThis paper describes a numerical example of the application of (swarm technique) water swirl algorithm that may be of help.
PDF -
ABHINANDthank u sir!
when will the rotor angle change in large alternators???
No doubt jQuery is most popular framework for Java Scripting on web. But novice developers feel it very complex. So here is Angular js to simplify dynamic java script framework...
Then GSM TDMA system uses a 270.833 kbps data rate to support eight user per frame,
1) What is the rate data provided for each user?
2) if guard time,...
CAN ANY ONE TELL???PLZ...
1.what is the work of civil engineers in rocket launch stations?
2.What are the structures need to be designed at rocket launch stations
Sony’s PlayStation 4 will be incapable of playing DVDs and BluRay discs when it is launched next month. Apart from optical media playback PS4 will also be missing the most...
