Using headphone as a microphone
Did you know that you can quickly turn your headphone into a microphone? And there's no rocket science or audio engineering involved. All you need to do is plug-in your headphone into the standard microphone port on your computer, and turn on any audio recording software. I remember having tried it years ago using my Windows Vista machine and Audacity audio recording software. While the quality of the sound isn't very great, it does the job. Imagine a case where you want to make a Skype call through your PC and you don't have a mic (and your computer doesn't have an inbuilt one; highly unlikely these days).
All you will have to do is simply put the headphone jack into the microphone jack and start speaking into the earphones as if it's a mic. Should solve the problem temporarily. I found it surprising that not many people know this trick! But you do, now!
This is possible because the working principle of both headphone and microphone is the same. The vibrations are converted into electrical in a microphone energy and vice-versa in a headphone. I haven't tried the trick in recent times, but if you have a separate audio/mic port on your system, you should give it a try. Do let me know if it works.
Also check if you can get any sound output if you plug-in your microphone in the headphone jack. Don't blame me if you damage anything in the process. Should be worth the try and the chances of damage are very minimum. ๐Ÿ‘
  • Anoop Mathew
    @anoop-FRTf1L • May 13, 2014
    Kaustubh KatdareDid you know that you can quickly turn your headphone into a microphone? And there's no rocket science or audio engineering involved. All you need to do is plug-in your headphone into the standard microphone port on your computer, and turn on any audio recording software. I remember having tried it years ago using my Windows Vista machine and Audacity audio recording software. While the quality of the sound isn't very great, it does the job. Imagine a case where you want to make a Skype call through your PC and you don't have a mic (and your computer doesn't have an inbuilt one; highly unlikely these days).
    I had tried this earlier, but it didn't work. Which was that headphone that you used? ๐Ÿ˜’๐Ÿ˜ฒ
    @sarathkumar-FEGRPw • May 13, 2014
    It is really fascinating but couldn't believe .I wonder about the possibility of it!
    Is there any experts out there to prove with brief explanation .
    Thanks for info.
  • lal
    lal
    @lal-R60Xjx • May 13, 2014
    Speaker: Converts electrical energy to sound ebergy/let us say vibrations.
    Mic: Converts sound/vibrations to electrical energy.
    And the setup is same. A coil vibrates in a magnetic field. In the speaker, electrical enrgy flowing through a coil interacts with the constant magnetic flux produced by a permanent magnet and makes it vibrate. A diphragm connected to the coil reflects these vibrations making sound. The same way, vibrations caused by sound on a diaphragm are transferred to a coil in the microphone which would then induce electric energy corresponding to the sound.
    Refer: Faradys law of electromagnetic induction
    Limitations: a speaker has a pretty tough diaphragm and coil, where as the microphone sports the same things which are pretty light and much more flexible. A speaker when made to work as a mic, would fail to respond well to the sound energy, because the energy isn't just enough. Yet, theoretically, there is energy conversion there, which could be feable. Talking loud and higher amplification should help get better output. If a mic is to be used as a speaker, it depends on the power output of the port if the mic will live ๐Ÿ˜
    lalSpeaker: Converts electrical energy to sound ebergy/let us say vibrations.
    Thanks to big explanation .
