Thermal Analysis
Hi Dudes, I'm currently working on a project where i'm using Ni-chrome wire as a heating element. I stuck in a place where I cannot exactly find the increase in temperature of the Ni-chrome wire theoretically at various time period that could match the experimental value. so, someone please help me out.
Here is the situation, I'm using a Ni-chrome wire of 1 m length, diameter of 0.37 mm, current and voltage to be 1.5 A and 18.4 V respectively. The resistivity value of the wire is found to be 1.3x10^-6 ohm m which lies in the resistivity range of the Ni-chrome wire. By joules law of heating I can be able to find the heat dissipated by the wire, As the voltage and the temperature are maintained constant. (H=I^2*R*t) so i find the heat dissipated by the wire in joules. In order to find the increase in temperature of the wire I'm using Enthalpy relation H=m*cp*dt as the internal energy changes because of the heat generation/dissipation of the wire due to the supplied voltage. I know the mass of the wire and the specific heat capacity of the wire by this I should be able to find the change in temperature. But the fact I cannot able to find the change in temperature as experimented. Here are my experimental values . The mass of the wire is 4grams and the specific heat capacity value is 450J/kg K.
Time (sec) Temperature (degree Celsius)
10 27.4
20 28.8
30 29.9
40 31.0
50 31.8
60 32.5
Some one help me out. Thanks in advance
