The "subplot" command in MATLAB
Everytime I try the subplot command in Matlab command window, it says rectangular wave instead of showing the description about it. I tried reinstalling it but problem persists.
The funny thing is, the same version of MATLAB in my friendโs laptop shows correct output. I actually tried another version of MATLAB, but that did not solve the problem. Can someone help me figure out the problem and its fix?
Answer:
Based on your description, it seems like your MATLAB environment might have been corrupted or there might be some code running automatically which is redefining the built-in "subplot" function. Here are a few steps you can try to solve this:
Check for name conflict: There could be a user-defined function or script named "subplot" in your MATLAB path that's overriding the built-in MATLAB function. Type
which subplot -allin the command window. If there is more than one file named subplot, MATLAB is likely using the one that appears first, which might not be the built-in function. If that's the case, you need to either rename the user-defined function or change the MATLAB path order.Clear Function: MATLAB caches information about functions for performance. Use the
clear functioncommand to remove all functions from the memory.Reset MATLAB path to default: Use the command
restoredefaultpathto reset your MATLAB path to its default state.Start MATLAB with no startup files: In some cases, the MATLAB startup might contain commands that redefine "subplot". Starting MATLAB without these files can help identify the issue. You can do this by opening the MATLAB executable with the
-nodesktop -noFigureWindowscommand line options.Check your startup folder: MATLAB runs the
startup.mfile located in the MATLAB startup directory when it starts. Check this file for any redefinitions of thesubplotfunction.Reinstall MATLAB: If all else fails, you may need to reinstall MATLAB. But before you do that, make sure to remove all settings and files related to MATLAB from your system, including in the user directory and the system directories.
These solutions should help you debug the problem. You may want to check out the MATLAB user community or MATLAB's own technical support if the issue continues to persist. They might have encountered similar issues and could provide additional solutions.
