Solar power generation with auto tracking system
cheppanuga
@cheppanuga-LttEcc โ€ข Oct 26, 2024
hello friends..this is my project and am currently working on it ..so am a little bit confused with its structure and components..so if you have already done this project or if you are aware of this project please inform me...you can also mail me vedios,ppt,pdf files and images to my mail #-Link-Snipped-#
tHaNk yOu
  • [Prototype]
    @prototype-G9Gn5k • Oct 1, 2012
    Videos, ppts, pdf, forget that. You will not get that here.W are here to help and not to spoonfeed. You are stuck with something ask.
    To get you moving i will just draw a raw image.
    1. Rotate the solar panel 360 degrees and sample the values of light intensity at particular duration. Find the highest intensity and start rotating again until you position to that point.
    2. You can even use a stepper motor and synchronize it with timing. Like every hour the panel will rotate X amount which is proportional to the movement of sun [I know sun dont move but to keep it easy let it move] every hour
    The physical design is pretty straightforward.
    @ramani-VR4O43 • Oct 1, 2012
    Cheppa pote maku etla teliyali? Unless told how will we know?
    Back in the early 70s MIT developed a passive solar tracking system using a bimetallic strip wound into a coil. The coil would unwind in the heat of the sun. A radially distanced shade was attached to a spoke on the shaft carrying the coil. In the sun the coil would start rotating the shaft till the shade started covering the coil. At this point the rotation would stop. The accuracy may be 10 degrees off. However this no matter as cosine of this deviation is more than 0.98
  • Kalpesh Salodiya
    @kalpesh-salodiya-kX6Kfx • Sep 16, 2014
    Thank you so much sir.....
