  • Significance of "Random" in RAM [Random Access Memory]
    Ashraf HZ
    Member
    Updated: Oct 18, 2024
    I thought I'd add in some additional questions, so our responses will be holistic.
    Also, analogies are highly encouraged, just like MaRo has done.
    - What is the significance of random in "RAM"?
    - Differences between DRAM, SRAM and ROM?
    This will definitely help answer question 2 of Biggie's thread here: #-Link-Snipped-##-Link-Snipped-#
    AdministratorOct 6, 2009
    Re: What is the role of RAM in a computer?
    ash
    This will definitely help answer question 2 😀
    Bang!
    Moving this to a separate discussion thread 😁 . Quite interesting, right?
  • Ashraf HZ
    MemberOct 6, 2009
    Thanks, though I hoped those points will help others understand the "whys" of main memory of your original thread 😛
  • faizaan
    MemberOct 6, 2009
    hi,
    my point of view is that
    As we know RAM is a kind of main memory which is much faster than auxilary memory (hard disk).But reason why ram is fast is because of access to any location in RAM is independent of it's location i.e random where as in hard disk it always depend upon the current position of read-write head so always delay is encountered in positioning the read-write head at required location .So "random" in RAM is because it takes almost same time to access any random memory location in RAM.
    DRAM-these type of RAM contains data in form of charge stored in capacitor,but this charge always leak after specific time so DRAM always needs to be refreshed after every small intervals and its frequency can be 667Mhz ,800Mhz... (it is the frequency at which DRAM is refreshed).
    SRAM-these type of ram are made of flip flops so here there is no fear of leakage of charge so there is no need of refreshing.That's the reason SRAM are sometime used as high speed cache memory.
    correct me if i am wrong.
  • MaRo
    MemberOct 6, 2009
    - Random :- means it can get the required data anywhere in its medium, opposed to "Sequential" which means you have to read all the data till the required point, which is sufficient for computer architecture, so Random is the efficient way for computer usage.
    It satisfy the random concept by dividing the memory into addresses & fetch the required address directly.
  • safwan
    MemberOct 6, 2009
    what my Hardware nots says ( Given by my teacher in school) 😛
    Memory is a workspace for Computers Processor
    A Temporary Storage Area Where the programs and data being operated on by the processor must reside
    It is called Random Access because you can randomly access any part of the memory (not sequentially)
    Difference between DRAM , SRAM, and ROM
    DRAM
    It is dynamically accessed and is very dense very large data can be stored in very less space
    It’s a bundle of capacitors which stores a charge to indicate a bit
    the charge must be constantly refreshed else the electrical charge will be drained and data will be lost
    Refresh occurs when the memory controller takes a tiny break and access all the rows of the data in the memory chip (controller is usually build in the north bridge of the mother board)
    The refresh rate is usually 15MS (micro seconds)
    That means every 15Ms all the rows in the memory are read to refresh the data which takes processors time
    You can alter the refresh rate from BIOS but this could lead to soft errors
    Modern systems don’t allow to change the refresh rate , the mother board usually read the refresh rate from the SPD (Serial Presence Detect) Rom found on the memory module and sets the cycling speed to match it )
    Dram uses one transistor and capacitor pair per bit with a dense arrangement offering more memory capacity per chip they are usually arranged in a normal grid fashion
    Each transistor reads the adjacent capacitor if the capacitor is charged the cell is read containing 1 else its 0
    DRAM is much cheaper then the SRAM because of its dense nature where millions of capacitors can fit a real small space
    SRAM
    Static RAM is faster then the DRAM
    SRAM uses a cluster of six transistors for each bit of storage , the usage of transistors instead of capacitors means no refresh is needed which makes it faster then the DRAM
    Since SRAM uses 6 transistors for one bit storage the size of the chips are big
    Bigger chips stores lesser data compared to DRAM size and storage capacity
    More over they are more expensive then the DRAM
  • safwan
    MemberOct 6, 2009
    Physically SRAM is 30 times larger physically & 30 times more expensive then the DRAM
    For Example DRAM of a given size can save up to 64Mb of data where as SRAM of same size can only save 2MB of data
    SRAM takes only 2ms (micros seconds) to read data
  • Mahesh Dahale
    MemberOct 6, 2009
    allow stored data to be accessed in any order (i.e.random).
    The word random thus refers to the fact that any piece of data can be returned in a constant time,
    regardless of its physical location and whether or not it is related to the previous piece of data.
    DRAM
    -Dynamic RAM has to be dynamically refreshed all of the time or it forgets what it is holding.
    -has memory cells with a paired transistor and capacitor requiring constant refreshing.
    SRAM
    -a form of flip-flop holds each bit of memory
    -A flip-flop for a memory cell takes four or six transistors along with some wiring, but never has to be refreshed. This makes static RAM significantly faster than dynamic RAM
    ROM
    -also known as firmware
    -an integrated circuit programmed with specific data when it is manufactured.
    -ROM chips are used not only in computers, but in most other electronic items as well.
