Shape Shifting Polymer Triggered By Body Temperature Can Lift 1000 Times Its Mass
Raagavan Sivaraja
@raagavan-sivaraja-mBq7hN • Oct 26, 2024
Prof. Mitch Anthamatten and his team at University of Rochester have identified a new way to tune polymers so that they react to heat triggers as minor as touch of a finger. These polymers are similar to a rubber band, but they can hold the shape when stretched until they get an external trigger of body heat. In this case, this polymer can respond to temperatures as low as 35°C. And when it uncoils back, the mechanical work done is capable of lifting 1000 times the weight of the polymer.
shape-memory-polymer-rochester-university​
Another finding that sets this apart from previous shape-shifting polymer researches is the measuring of mechanical work done by the polymer as it retreats to its original shape. This polymer was fabricated in a way that it stores massive amounts of elastic energy, so that when they rebound to their original shape, the work done was also massive.
When this material is stretched or cooled, small segments of the polymer group together and form rigid structures called crystallites. These crystallites are responsible for the polymer being locked in a temporary shape. And when cooled, these crystallites gave way for the polymer to shift back to the original shape. The number of such crystallites is proportional to the strength and stability of the polymer, so for the polymer to easily regain its original shape, the number of crystallites had to be controlled.
Prof. Anthamatten and graduate student Yuan Meng identified that introducing molecular linkers hindered the crystallization process significantly. By varying the number of linkers used, they were able to tune the polymer to a specific temperature at which it begins to morph to its permanent shape, ideally a little less than body temperature.
The polymer being so sensitive and specific to body temperatures will open avenues in a variety of medical researches such as artificial skin, automatic medical dispensers and sutures used to stitch up wounds and surgical incisions.
Source: <a href="https://www.rochester.edu/newscenter/body-temperature-triggers-newly-developed-polymer-to-change-shape-138472/" target="_blank" rel="nofollow noopener noreferrer">Body heat triggers shape change in new type of polymer : News Center</a>
