Servo control with Sine cosine potentiometers.
AndreyG
@andreyg-PYg3bH โ€ข Oct 12, 2024
I have controller and motorized rotating device. The Controller is a knob the User can rotate. The rotating device is Propulsion Nozzle. Both the Controller and the Nozzle can be rotated over full 360 degrees โ€“ no limits. Both Controller and device are equipped with Sine Cosine Potentiometers.
I need the Nozzle to follow the Knob. In order to do that I need to compare output signals from the two sine cosine potentiometers and generate error signal. Error signal activate the motor and make the nozzle turn to follow the controller.
I am looking for simple (and preferably analog) way to compare outputs of the two Sine Cosine Potentiometers and generate error signal.
I expect there should be analog way to do it because the sine cosine pots were around before digital techniques came to being.
  • narayana murthy
    @narayana-z4W16q • Feb 4, 2011
    What you exactly needed please specify it otherwise no one can help you
  • AndreyG
    @andreyg-PYg3bH • Feb 4, 2011
    I need circuit or algorithm where inputs are signals from Sine Cosine pots and output signal indicates direction in which to rotate the nozzle to match outputs of sine cosine pots.
