RFID controlled lights
CorbettROV
@corbettrov-mWeIPf โ€ข Oct 22, 2024
Hey, I'm looking into doing a project over the summer that uses an RFID module to turn the overhead lights in my room on and off. I have been thinking about it, and it seems like it would be easiest to use a Parallax RFID module, a BASIC Stamp controller, and a relay. It would be even simpler if this were to exist, but I doubt it does: an RFID with a built it relay that atuates the relay when the RFID is triggered.
So back to my original idea: if I hook up an RFID module to a BASIC stamp, and then to a relay, what kind of relay would I need to get? Could I power my BASIC Stamp and my RFID off of the same power source? The RFID requires 5VDC and the BASIC Stamp requires 6-9 VDC, so I'm thinking it would't work. Also - what weould power the relay? Would the battery connected to the BASIC Stamp be able to actuate the relay?
Thanks! Jacy๐Ÿ˜
  • sauravgoswami
    @sauravgoswami-UAfTlI • May 26, 2009
    Both RFID and BASIC stamp can be powered through same power souce as for relay how voltage you are going to apply at NO and NC connections???
