Researchers Develop Micro-sized, Liquid-Metal Particles For Heat-Free Soldering
Scientists at Iowa State University in USA have successfully developed micro-scale, liquid-metal particles which can be put to use for heat-free soldering, fabricating, repairing and processing of metals - all at room temperature. The project was initially undertaken as a search for a way to stop liquid metal from returning to a solid â even below the metalâs melting point. Something known as âundercoolingâ in the field of metal structure and processing.
Martin Thuo holds a vial of the liquid-metal particles produced by his research group
Martin Thou, an assistant professor at Iowa State University and his group created liquid-metal particles containing Fieldâs metal (an alloy of bismuth, indium and tin) and particles containing an alloy of bismuth and tin. The particles are 10 micrometers in diameter, about the size of a red blood cell. These were exposed to oxygen after which an oxidation layer was allowed to cover them, essentially creating a capsule containing the liquid metal. The layer is then polished until it is thin and smooth.
The tiny droplets of liquid metal are covered with a thin, uniform coating, so as to form stable particles of undercooled liquid metal. The researchers wanted to essentially build a system where the metals donât turn into solids.
These liquid metal particles could have significant implications for manufacturing. It could aid in healing of damaged surfaces and soldering/joining of metals at room temperature without requiring high-tech instrumentation, complex material preparation or a high-temperature process. In the research scientists also note to have experimented with a new technique that uses a high-speed rotary tool to sheer liquid metal into droplets within an acidic liquid.
It had always been a challenge to produce large and stable quantities of undercooled metals however with this breakthrough, practical, sustainable and inexpensive solution to the problem seems plausible.
The research was published in #-Link-Snipped-#
Source: <a href="https://www.news.iastate.edu/news/2016/04/25/liquidmetal" target="_blank" rel="nofollow noopener noreferrer">Iowa State engineers develop micro-sized, liquid-metal particles for heat-free soldering • News Service • Iowa State University</a>
