Reaction Force on bolt due to Forward/Upward Force of object
*Note: Not necessary to answer all the question. even one answer is highly appreciated.
Hi guys,
I am currently seeking a correct approach of getting the reaction force developed on bolt due to the Forward or Upward force experience by the object as per regulation of Title 14 CFR 27.561.
Imagine I have a box secure on plate by 4 bolts in symmetrical way. The box will experience forward force of 20 forward or 4g upward. Hence I have to select the bolt that can withstand these condition. Initially for both cases, I would simply divided the force by 4 to find the reaction on bolt with assumption the C.G of box is located at nicely at the middle between 4 bolt (symmetrical).
Since I would like to know the proper way of finding this reaction force, I have develop a FBD for this case as below.
Basic:
Box experiencing upward force case;
Box experiencing forward force case;
*A and B are Bolted connection, so I am using fixed support. However still not sure if it the correct presentation anc correct support. Correct me if I'm wrong in presenting it.
*Neglecting the effect c.g of plate as it thickness is negligible.
My main concern to find is only on the reaction forces and my question are:
1) Does my basic understanding in this case is correct based on the FBD above?
Upward Force case:-
2) Does it simply divided by 2 to find Rxa or Rxb(due to symmetrical)?, and divided again by 2 to find force on each bolt (4 bolt in symmetrical position, 2 front:2 back)
3) Does height of C.G have effect on finding value of Rxa or Rxb?
4)I might encounter case where the c.g is not symmetrical with bolt. it is applicable using this equation for this case(diagram below). Since I'm not sure weather it is compatible with my FBD or not.
5) is this equation valid for upward case above? and if upward force is not in symmetry between the bolts, does Rx still zero?
Forward Force case;
5) to find Rxa, I would simply divide by 2 as per Figure below and divide by 2 again to gain force in each bolt (not shown in figure). Is this correct?
6) If the c.g is not located at the middle between Fxa and Fxb, does equation as figure above applies? (in other word, does location of c.g have effect on shear stress?)
7) If there is more bolts like 3 pairs at the back and 3 pairs at front (Fxa & Fxb have pair of bolt, Figure below). Does shear force (Fx) is same for all pairs of bolt regardless its position.
Sorry for asking very much question, just need to clarify. Feel free to answer any question. Would be glad if you all could help me although with one answer. Do not hesitate to share your opinion.
Thank you.
Hi guys,
Basic:
Upward Force case:-
Forward Force case;
Thank you.
Ramani Aswath
Whenever a bolt is tightened there is a tensile force on the bolt related to the amount of tightening. This can be high enough to shear the bolt if a torque limiting wrench is not used. This will come on top of whatever forces come from the above set up. Has this been considered?A. AzizDo not hesitate to share your opinion. -
A. Aziz
Yes Mr Ramani,A.V.RamaniWhenever a bolt is tightened there is a tensile force on the bolt related to the amount of tightening. This can be high enough to shear the bolt if a torque limiting wrench is not used. This will come on top of whatever forces come from the above set up. Has this been considered?
I found out that the tensile force generated on the forward case is significantly high and can't be simply ignored.
I calculate the tensile force of section A and B for forward case by using moment coupling formula. Someone told me about this method and i'm still lack understanding about how this moment coupling formula is derived.
They said moment coupling is only applicable for symmetry case like above, but need to calculate the moment generated on beam first due to forward force (located on plate and parallel to the C.G, moment location denoted as O).
Is the method use is correct?. then is there is another approach?
Thank you. -
Ramani Aswath
I have not yet got to the main issues raised. I am talking about the tensile force by just tightening the bolt. This will be present even if there is no motion at all.A. AzizI found out that the tensile force generated on the forward case is significantly high and can't be simply ignored. -
A. Azizyes sir,
I have calculated and considered the tension force due to tightening torque. -
A. AzizA.V.RamaniI have not yet got to the main issues raised. I am talking about the tensile force by just tightening the bolt. This will be present even if there is no motion at all.
The tension force due to torque is significant sir,
so does that mean that I have to add the tension force onto the reaction force Fya when it experience forward/upward force? -
Ramani AswathWhen there is a forward acceleration, you will get a shear force in the opposite direction. When there is a downward acceleration there will be an axial tensile force. This will be nx(total weight of the (box+contents) at rest), where n is the acceleration. This can be divided into all four bolts equally assuming symmetry.
Note that if the acceleration is upward there is no tensile force on the bolts as the box is being pressed down onto to the floor board by its weight. -
A. Azizokay sir, i take note on that.
Thank you sir
Hello, Need a piece of advise on career. I'm a BE (ECE) 2012 graduate and have worked as a Technical Support Engineer for Printers & Scanners team in MNC for...
Microsoft engineers are working on making their search app 'Bing' faster and better. A couple of days back, they released the Bing for iPhone app (version 6.0) on the Apple...
China's next-gen heavy lift launch system called 'Long March 5' is currently under testing at the CALT, short for China Academy Launch Vehicle Technology. The powerful space rocket is also...
Hello sir/ma'am,
This is Arha ,I have completed my mtech first year in structural engineering ,now need to head towards the project ,so kindly suggest me a project which help...
What is the difference between air conditioner and refrigerator ?
