  • rack and pinion calculations
    hinduja.prasad
    hinduja.prasad
    @hindujaprasad-OxDtiD
    Updated: May 10, 2009
    Views: 2.3K
    hiiiiiiiiiii............
    i 😕am having problems with rack and pinion calculatons.................can ny i plsssssss give me the formula in terms of pitch of the rack and the no. of teeth
    of the pinion. i need to findout the teeth spacing on the rack and pinion........... that can help me calculate the distance moved by the rack for 1 rotation of the pinion...........
    thanx.............😛
  • Tkelly
    MemberMay 31, 2009
    Without knowing the load to be moved, you can not decide the pitch of Rack & Pinion.
    Also mention the distance of the rack you required to mave by one revolution of pinion.
    Tom
    <a href="https://www.indovance.com" target="_blank" rel="nofollow noopener noreferrer">CAD Outsourcing Services India | Indovance Inc</a>
  • hinduja.prasad
    MemberMay 31, 2009
    ok....thanx for the reply but the problem is i am using this steering and i have a particular steering ratio in my mind. and yes i also know the total rack length and dia of the pinion. so can u plsssssssss 😔 help find out pitch.........
  • Tkelly
    MemberJun 5, 2009
    There is formula for calculating the pitch, but it also requires the technical data as written earlier.
    Tom
  • zorif
    MemberJun 8, 2009
    in Rack and pinion
    first u need to know the load,to choose the module type.ie.module1,1.5 etc.higher the module more distance u will travel for one rotation of pinion.and lower the resolution will be.
    you need to have the gears technical handbook to choose the appropriate rack and pinon.give me some time i will post the gear reference manual.using which u can do the module and pitch calculations.
  • Tkelly
    MemberJun 11, 2009
    Zorif is right. I also suggested same thing.
    From the load you can decide module od DP ( in inches). Once you know the module, you can calculate further data from gear design handbook.
    Tom
  • kurtdaniel
    MemberSep 22, 2009
    zorif
    in Rack and pinion
    tnx..for this info..hope it will be completed soon.,Im gonna subscribe to this thread cause I really need a solution for my rack and pinion and other #-Link-Snipped-#..😒
  • satanas
    MemberNov 3, 2009
    hi, i would like some information about " how to mount a rack and pinion in the vertical plane".. the pinion will be moving the rack, which will follow a reciprocating vertical motion.. the load is aprroximately 3 kg.. any recommendation on wat type of rack should i use?
    thx beforehand..
    satanas..
  • madhukar0028
    MemberSep 1, 2010
    hi.......can someone tel me how to calculate rpm of pinion in rack pinion mechanism.........
    thanx
  • Soham De
    MemberNov 2, 2014
    Dear Sirs i want to know the standard rack and pinion gear dimensions for the steering . where cn i get that I hv my load details!!!
  • Soham De
    MemberNov 2, 2014
    zorif
    in Rack and pinion
  • entrepreneur
    MemberDec 23, 2015
    i need 1:2 steering ratio can u plz hlp me?????
  • Anjudivi
    MemberMar 4, 2016
    Hii . Actually i want to knoe the formula for 1/16th distance travelled on the work piece which has rack and pinion movement . Can u plz help me out
  • Anjudivi
    MemberMar 4, 2016
    Plzzzz plzzz ans me fast
  • Kalaiyarasan Rajendran
    MemberMar 4, 2016
    check out the link.!
  • Anjudivi
    MemberMar 4, 2016
    Actually wanted to knoe the distance travelled not the load which is kept
  • Anjudivi
    MemberMar 4, 2016
    Thnks 4 try 2 help me out but the link which u sent me does not contain the info which i want
    MemberMar 5, 2016
    oops.!! sry 2 hve👎
  • mahesh patki
    MemberFeb 12, 2017
    please send me rack and pinion calculations pls fast
